Repeated applications of sinusoidal functions
In summary: Fourier analysis is a mathematical technique used in many disciplines, such as physics, engineering, and music. It is a way of analyzing periodic phenomena, in particular, by decomposing them into sines and cosines of various frequencies. This allows for an understanding of the behavior of the system at various frequencies. Fourier analysis is also used in other fields, such as meteorology and optics, to analyze signals.
lordkelvin
has any work been done trying to understand the properties of long chains of oscillatory functions?
like f(x) = sin(sin(sin(sin(cos(sin(cos(x))))))) for example, or something like e^e^e^e^e^e^e^e^e^e^z)
Hey lordkelvin.
In terms of functions like yours, unfortunately for most purposes the functions that most people analyze are a lot simpler than this.
Usually if we have a really complex kind of function or a signal, then we usually "project" it to some specific basis and then possibly use only a fraction of the information that represents the original function or signal.
In terms of oscillatory functions, you might benefit from looking at Fourier analysis for periodic functions. This is a staple way of analyzing periodic phenomena in a standard way. What this does is it says that periodic functions can be decomposed into sines and cosines of various frequencies.
You can look at the information in the frequency domain to get an idea of what is going on as the frequency gets higher and higher.
For slightly simpler problems much is known. In your first example, using both sines and cosines makes it more difficult to handle than if you had just used one or the other. So, I'll just use one kind of function in my following explanation.
Consider some function f(x). Let
[tex]f_n(x) = \underbrace{f \circ f \circ f \circ \dots f}_{\rm{n~times}} (x),[/tex]
such that [itex]f_1(x) = f(x)[/itex]. It can be seen that [itex]f_{n+1}(x) = f(f_n(x)),[/itex] or, letting [itex]x_j \equiv f_j(x)[/itex] to make it cleaner,
[tex]x_{n+1} = f(x_n),[/tex]
with x_0 = x.
This is just an iterated map: you pick an initial value for x, and then you plug it into your function, take the output, and plug it back into the function, and so on. There are a few possibilities for the behavior of the iterated function. Typically, as you iterate this more and more you will approach a certain limiting value, called a fixed point. A fixed point is a value of x for which x = f(x), and for convenience the possibility of [itex]x = \pm \infty[/itex] is included. If your initial point is a fixed point, you just keep getting that fixed point back. If your initial x is not a fixed point, the function will flow towards a fixed point as you keep iterating the functions. If the function has more than one fixed point, which fixed the function approaches as you iterate will depend on your initial value of x.
Another possibility is that there are no fixed points and you end up in a cycle - e.g., a two period cycle for which y = f(x) and x = f(y), so you don't approach a limit as you keep iterating, you just end up bouncing back between these two points. Higher-period cycles are also possible.
Another possibility is chaos - iterations do not approach any sort of limit and the output appears to be random.
So, for a concrete example, if f(x) = cos(x), then asking what does the function
[tex]f_4(x) = \cos(\cos(\cos(\cos(x))))[/tex]
do, you'll get some function of x - the output will depend on the initial condition, but if you trying looking at more and more iterations of the cosine, you should find that the function is close to value 0.739085, which is the solution to x = cos(x). This will be the value of [itex]f_\infty(x)[/itex], for any x. For finite numbers of iterations, the function [itex]f_n(x)[/itex] will be close to this value, but there will still be variations. If you check [itex]f_n(0.739085)[/itex], you should find that it is close to 0.739085 (it may not match exactly due to numerical roundoff).
You could similarly try f(z) = exp(z), but for z real you find that the only fixed point is z = infinity.
I'm not sure what happens if you start randomly switching functions in the iterations. I imagine people have probably studied iterated maps where you switch the function every other iteration, e.g., x_n = f(y_n), y_n = g(x_n), but if you randomly switch a function I imagine it's much harder to analyze in complete detail.
Some relevant wikipedia pages:
http://en.wikipedia.org/wiki/Logistic_map
http://en.wikipedia.org/wiki/Cobweb_diagram
http://en.wikipedia.org/wiki/Iterated_map
http://en.wikipedia.org/wiki/Chaos_theory
Related to Repeated applications of sinusoidal functions
1. What is a sinusoidal function?
A sinusoidal function is a mathematical function that represents a repeating wave or oscillation. It is commonly seen in trigonometric functions such as sine and cosine.
2. How is a sinusoidal function graphed?
A sinusoidal function is graphed by plotting the values of the function over a specific range of the independent variable. The resulting graph will have a repeating wave pattern.
3. What is the period of a sinusoidal function?
The period of a sinusoidal function is the distance between two consecutive peaks or troughs of the graph. It is also equal to the length of one full cycle of the function.
4. Can sinusoidal functions be used to model real-world phenomena?
Yes, sinusoidal functions can be used to model many real-world phenomena such as sound waves, ocean waves, and even the movement of planets in our solar system.
5. How are repeated applications of sinusoidal functions useful?
Repeated applications of sinusoidal functions are useful in analyzing and predicting the behavior of systems that exhibit periodic patterns or oscillations. This can be applied in fields such as physics, engineering, and economics.
