Replacing Variables in Integration
In summary, the conversation discusses the process of evaluating the integral $$I = \int_{-\infty}^{\infty} e^{-x^2} dx$$ and explores how it can be represented using different variables. It is shown that the integral can be viewed as a product of two integrals, with each variable representing a different axis. This allows for a better understanding of the process and leads to a clearer geometric representation of the integral.
Amad27
412
Below
I don't understand, we say:
Then we say:
$$I = \int_{-\infty}^{\infty} e^{-t^2} dt$$
I want to see how this process works?
We consider
$$f(x) = e^{-x^2}$$
Right? Then we say that:
$$f(t) = e^{-t^2}$$
Right? Ideally we are replacing x with t correct? Then we say: where R is the whole real axis.
$$I^2 = \int_{R} \int_{R} e^{-(t^2 + x^2)} dtdx$$
But the problem is that now you consider t and x different axes, while before they lay on the same axis.
How does this work?
This is more a bookkeeping problem than anything else.
## I = \int_{-\infty}^\infty e^{x^2} dx ## when you square this, you get ## I^2 = \left( \int_{-\infty}^\infty e^{x^2} dx\right)^2 ##
Since you need to be careful not to simply see this as ## \int_{-\infty}^\infty (e^{x^2})^2 dx##, the addition of a second variable is useful.
## I^2 = \left( \int_{-\infty}^\infty e^{x^2} dx\right) \left( \int_{-\infty}^\infty e^{x^2} dx\right)= \left( \int_{-\infty}^\infty e^{x^2} dx\right) \left( \int_{-\infty}^\infty e^{t^2} dt\right) ##.
Then, becuase these are two continuous functions, you can combine the integrals...
## I^2 = \int_{-\infty}^\infty \int_{-\infty}^\infty e^{x^2} e^{t^2} dxdt = \int_{-\infty}^\infty \int_{-\infty}^\infty e^{x^2+t^2} dxdt ##.
This is not a geometrical problem, so there is no need to worry about axes, you are just trying to account for every term on the real line being multiplied by every other term on the real line. If it helps you to visualize it, give the variables different names, like ##x_1 ## and ##x_2##. The result should be the same.
I=∫∞−∞ex2dx I = \int_{-\infty}^\infty e^{x^2} dx when you square this, you get I2=(∫∞−∞ex2dx)2 I^2 = \left( \int_{-\infty}^\infty e^{x^2} dx\right)^2
Since you need to be careful not to simply see this as ∫∞−∞(ex2)2dx \int_{-\infty}^\infty (e^{x^2})^2 dx, the addition of a second variable is useful.
I2=(∫∞−∞ex2dx)(∫∞−∞ex2dx)=(∫∞−∞ex2dx)(∫∞−∞et2dt) I^2 = \left( \int_{-\infty}^\infty e^{x^2} dx\right) \left( \int_{-\infty}^\infty e^{x^2} dx\right)= \left( \int_{-\infty}^\infty e^{x^2} dx\right) \left( \int_{-\infty}^\infty e^{t^2} dt\right) .
I2=∫∞−∞∫∞−∞ex2et2dxdt=∫∞−∞∫∞−∞ex2+t2dxdt I^2 = \int_{-\infty}^\infty \int_{-\infty}^\infty e^{x^2} e^{t^2} dxdt = \int_{-\infty}^\infty \int_{-\infty}^\infty e^{x^2+t^2} dxdt .
This is not a geometrical problem, so there is no need to worry about axes, you are just trying to account for every term on the real line being multiplied by every other term on the real line. If it helps you to visualize it, give the variables different names, like x1x_1 and x2x_2. The result should be the same.
I do not understand.
We are saying that $t = x$, then $dt = dx$
but If I want to see the geometric representation of the integral then I do not see how $t$ and $x$ would be the $xt$ plane. That is the question?
What if you replaced t with y? Would that make more sense?
The bottom line is that in the two integrations, you are varying x so that it can have one value in the first and a different value in the second. By only using x, this gets very confusing, so you use a different variable in the second integration.
A simple example is
##B = \sum _{i = 1} ^3 x ##
## B^2 = \left( \sum _{i = 1} ^3 i \right)^2 = (1+2+3)^2 =36##
##\left( \sum _{i = 1} ^3 i \right)\left( \sum _{i = 1} ^3 i \right)=\left( \sum _{i = 1} ^3 i \right)\left( \sum _{j = 1} ^3 j \right)##
##B^2 =\sum _{i = 1} ^3 \sum _{j = 1} ^3 ij = 1*1 + 1*2+ 1*3 + 2*1 + 2*2 + 2*3 + 3* 1 + 3*2+3*3 = 36##
I am not having trouble changing variables, I am having trouble converting it into 3D
But this is the issue:
$$I=\int_{-\infty}^{\infty}e^{-x^2} \, dx$$
What you are doing is:
let $x = y \implies dx = dy$ Then
$$I = \int_{-\infty}^{\infty}e^{-y^2} \, dy$$
But when you combine it:
$$I = \int_{R}\int_{R} e^{-(x^2 + y^2)} dxdy$$
This is really:
$$I = \int_{R}\int_{R} e^{-2x^2} (dx)^2$$
Applying $x^2 + y^2 = r^2$ requires $x$ to be perpendicular to $y$.
Which means it requires one to be the "range part," and one to be the "domain part." Doesn't it? Due to the Pythagorean theorem?
QUESTION #2
We defined in the beginning,
$$h(x) = e^{-x^2}$$
$$\therefore, h(y) = e^{-y^2}$$
But so $x$ and $y$ are colinear, lie in the same line. $y = x$ is not necessary. But still, when you make this 3D, $x$ and $y$ cannot have different axes can they? So it cannot be a multivariable function?
Remember that an integral is similar to a sum, and the product of sums requires crossing all the terms in each of the sums. What I am trying to demonstrate is that when you have a product of integrals, it is best to think of them as different variables and place them on two different axes. Think of the integral of x from zero to 4. This is easily evaluated as 8. The square of this integral should give you 64.
To plot this in 3D, you will have the same 2D plot in the xz plane and the yz plane. The stuff in between will be defined by z = xy, which along the line y=x will look like z = x^2 = y^2 .
The integral is ##\int_0^4 \int _0^4 xy dxdy = \int_0^4 8y dy =64##.
The integral is also ##\int_0^4 \int _0^4 x_1 x_2 dx_1dx_2 = \int_0^4 8x_2 dx_2 =64##.
The integral is not ##\int_0^4 \int _0^4 x^2 dxdx = \int_0^4 64/3 dx =256/3##.
And the integral is definitely not ##\int_0^4 x^2 dx = 64/3 ##.
@RUber I am starting to understand it more. I suppose from the beginning you considered, a multivariable function.
$$f(x,y) = e^{-x^2}$$
$$g(x,y) = e^{-y^2}$$
So that you didnt have to convert a 2D function to a 3D function correct?
Then h(x,y) = g(x,y)*f(x,y)
I cannot convince myself that changing variables is justified. How do you convince yourself that changing variables is justified (dummy variables etc...) Is it from the Definition of a general variable?
Thanks!
Dummy variables are inherent to integration, as they are in summations. Remember that you are multiplying the integrals, not the functions. In any two different integrals, it is often useful to use different variables to avoid confusion.
Amad27 said:
Right, they are free variables correct? Which is why they are interchangable? http://en.wikipedia.org/wiki/Free_variables_and_bound_variables
No, that link defines them as the bound variables in the integral. I.e. they are bound inside the integral and have no existence outside it. There are no free variables here since I does not depend on any variables, it's a constant.
Be warned that this gets confusing with indefinite integrals when written as ##\int^xf(x).dx##. There are really two different things called x there (I call this a pun). You can rewrite it as ##\int^{z=x}f(z).dz## without changing the meaning at all, and now we can see that z is a bound variable while x is a free variable.
Be warned that this gets confusing with indefinite integrals when written as xf(x).dx\int^xf(x).dx. There are really two different things called x there (I call this a pun). You can rewrite it as z=xf(z).dz\int^{z=x}f(z).dz without changing the meaning at all, and now we can see that z is a bound variable while x is a free variable.
Can we replace bound varialbes then?
Of course you can. The variables inside integrals are dummy variables. In the original problem, you did not have a function I(x), you had a number, I, which had no dependence on any variables. You can put x, y, t, bananas, etc. as the variable of integration and I will still be the same number.
When you square I, you introduce a second integral, and with is a second variable of integration.
I know we can do that, the accurate formal reason j can think of is that the the variables are BOUND variables it follows from definition then.
Informally I knew this. Formal reason is more important so is the above paragraph true? Thanks
I would not put formalism ahead of logic. It's more important to understand.
What I am asking, is, does that follow from definition of the bound variable?
Yes, it does. A bound variable may always be called by a different name within the confines of the bounded environment.
ex: ## \int _0^5 x dx = \int _0^5 a da ## or ## \lim_{x\to 0} \frac{\sin x}{x} = \lim_{h\to 0} \frac{\sin h}{h}##.
As in this problem, two separate integrals in x are fine, but in order to combine them, it is important to distinguish which x varies within which integral, that is why we replaced one x with t.
ex: ∫50xdx=∫50ada \int _0^5 x dx = \int _0^5 a da or limx→0sinxx=limh→0sinhh \lim_{x\to 0} \frac{\sin x}{x} = \lim_{h\to 0} \frac{\sin h}{h}.
Are we doing substitution actually?
In changing variables, are we for example saying $x = y$? If yes, then:
$$\int_{-\infty}^{\infty} \int_{-\infty}^{\infty} e^{-(x^2+y^2)} dxdy$$
But then how do we conclude that $x^2 + y^2 = r^2$?
Since x^2 + y^2 = 2x^2
In no way does x^2 + y^2 = 2x^2. This is not a substitution, it is a name change so you don't make that mistake. The x in one integral varies independently from the x in the other. That was the whole reason for the change of variables when you went to combine integrals. If you are plotting this on the x-y plane, x^2 +y^2 = r^2 is a very routine substitution.
I see. I still can't for some reason convince myself that this is from definition.
How do you personally convince yourself that we can change variables?
I've done it before hundreds of times, this was the example which made it all go crazy. I just can't justify it anymore...
The variable inside the integral is bound to the integral. It can be anything. If you want to call it something else, you can. No convincing necessary.
Look back to post #2, see that if you kept both integrals in x, you would end up with
##\int_{-\infty}^\infty\int_{-\infty}^\infty e^{-x^2 -x^2 } dx dx.## Which would be totally confusing since the first x is bound to one integral and the second x is bound to the other. At the very least you would need subscripts like ##\int_{-\infty}^\infty\int_{-\infty}^\infty e^{-x_1^2 -x_2^2 } dx_1 dx_2.## to keep them straight.
If you are asking about the polar substitution, you can always do that--I suspect that is the completion of the example you are working on which shows that ##I = \sqrt \pi##
∫∞−∞∫∞−∞ex2−x2dxdx.\int_{-\infty}^\infty\int_{-\infty}^\infty e^{-x^2 -x^2 } dx dx. Which would be totally confusing since the first x is bound to one integral and the second x is bound to the other. At the very least you would need subscripts like ∫∞−∞∫∞−∞ex21−x22dx1dx2.\int_{-\infty}^\infty\int_{-\infty}^\infty e^{-x_1^2 -x_2^2 } dx_1 dx_2. to keep them straight.
If you are asking about the polar substitution, you can always do that--I suspect that is the completion of the example you are working on which shows that I=π‾‾
The thing is that I want to know.
How do you convince yourself is what I am requesting, when you have time to respond.
I did not know bound variables etc... but I still used to changed variables.
I just accepted the fact that is doesn't change the value of anything.
But why is it true that it doesn't change the value of anything? There can't be a proof because of infinite symbols.
Then my question, how do you convince yourself?
Thanks @RUber !
Do you agree that ##\int_{A}^{B} f(x)\, dx \equiv \int_{A}^{B} f(y)\, dy##?
Is it clear to you that ##I## is not a function, but a single constant value defined by the integral ##\int_{-\infty}^{\infty} e^{-x^2} \, dx##?
Would it not be equally true that ##I=\int_{-\infty}^{\infty} e^{-y^2} \, dy=\int_{-\infty}^{\infty} e^{-t^2} \, dt##?
These facts require no substitution, since ##I## is still defined as the constant value given by the integral of the function ##f(x)=e^{-x^2}## over all real values.
It seems that where you get confused is when we are defining ##I^2##.
For this, recall that multiplying two integrals is like multiplying two sums, and you must take care to ensure that all crossed products are considered.
When doing this with sums, you might see something like:
##\left( \sum_{i=1}^n i \right)^2 = \left( \sum_{i=1}^n i \right)\left( \sum_{i=1}^n i \right)##
##= \left( \sum_{i=1}^n i \right)\left( \sum_{j=1}^n j \right)= \sum_{i=1}^n \sum_{j=1}^n i j ##
Note that if you fail to change the index variable (similar to the variable of integration), you would get:
##\left( \sum_{i=1}^n i \right)^2 = \sum_{i=1}^n \sum_{i=1}^n i^2 = n \sum_{i=1}^n i^2##
A simple check with n=2 shows that the first representation is correct and the second is not.
(1+2)^2 = 9 = 1*1 + 1*2 + 2*1 + 2*2
not 2( 1+4) = 10
It is not just that it does not change anything to change the variable, it is that it is required to change the variable if you want to write the product in a combined expression.
RUber said:
Do you agree that BAf(x)dx≡∫BAf(y)dy\int_{A}^{B} f(x)\, dx \equiv \int_{A}^{B} f(y)\, dy?
Is it clear to you that II is not a function, but a single constant value defined by the integral ∫∞−∞ex2dx\int_{-\infty}^{\infty} e^{-x^2} \, dx?
Would it not be equally true that I=∫∞−∞ey2dy=∫∞−∞et2dtI=\int_{-\infty}^{\infty} e^{-y^2} \, dy=\int_{-\infty}^{\infty} e^{-t^2} \, dt?
These facts require no substitution, since II is still defined as the constant value given by the integral of the function f(x)=ex2f(x)=e^{-x^2} over all real values.
It seems that where you get confused is when we are defining I2I^2.
(ni=1i)2=(ni=1i)(ni=1i)\left( \sum_{i=1}^n i \right)^2 = \left( \sum_{i=1}^n i \right)\left( \sum_{i=1}^n i \right)
=(ni=1i)(nj=1j)=∑ni=1∑nj=1ij= \left( \sum_{i=1}^n i \right)\left( \sum_{j=1}^n j \right)= \sum_{i=1}^n \sum_{j=1}^n i j
(ni=1i)2=∑ni=1∑ni=1i2=nni=1i2\left( \sum_{i=1}^n i \right)^2 = \sum_{i=1}^n \sum_{i=1}^n i^2 = n \sum_{i=1}^n i^2
not 2( 1+4) = 10
I want to agree that:
$$\int_{A}^{B} f(x) dx = \int_{A}^{B} f(y) dy$$
But I just cannot justify it for some odd reason!
I understand that $I$ is just a constant, not a function.
But the root of the problem is that I don't see how the result is going to be equal...
The reason they are the same is that the function does not care what variable you give it. Both integrals whether f(x) or f(y), will sum the range of values from f(A) to f(B). Note that neither x nor y appears in the evaluation.
To put that another way, the value of f(x) when x=2 is the same as the value of f(y) when y=2. In the integral, the 'x' is just a piece of machinery which supplies successive values of the range to feed into f. The result depends only on the value supplied, not the name of the agent that supplied it.
@RUber and @haruspex, the problem is that we are considering a whole different axis a different axis, let's say $t$ and $f(t)$
Wait, I sort of see it now.
But the thing I cannot understand is.
If $F$ is the antiderivative then how is.
$F'(t) = F'(x) = f(t) = f(x)$??
I touched on this in post #10. The equivalence of x and t as dummy (bound) variables does not support your antiderivative equation.
As I posted, ##F(x) = \int f(x).dx## is shorthand for ##F(x) = \int^x f(x).dx##. There are two different x's here, one bound and one free. It is clearer if rewritten as ##F(x) = \int^x f(t).dt##. Differentiating with respect to x produces ##F'(x) = f(x)##.
@haruspex, I am trying to understand. I want to ask the same thing I asked @RUber.
How do you convince yourself that it is fine to change variables? (For generally, sums, integrals, equations,etc...) ??
Related to Replacing Variables in Integration
1. What is the purpose of replacing variables in integration?
Replacing variables in integration allows us to simplify and solve complex integrals by substituting a new variable that makes the integral easier to evaluate. This can also help us to identify patterns and make connections between different integrals.
2. How do I know which variable to replace in an integral?
The variable to be replaced in an integral is usually the one that is causing difficulty in solving the integral. This could be a variable that appears multiple times in the integrand or a variable with a complicated function. It is often helpful to choose a variable that will result in a simpler integral after substitution.
3. Can I use any variable to replace in an integral?
Yes, you can use any variable to replace in an integral as long as it does not already appear in the integrand. However, it is common to use variables such as u, v, or t as they are commonly associated with substitution in integration.
4. What are some common trigonometric substitutions used in integration?
Some common trigonometric substitutions used in integration include sin(x), cos(x), tan(x), sec(x), csc(x), and cot(x). These substitutions can be helpful in solving integrals involving trigonometric functions or expressions that can be rewritten in terms of trigonometric functions.
5. Is it always necessary to replace variables in integration?
No, it is not always necessary to replace variables in integration. In some cases, the integral may be solvable without substitution or by using other integration techniques such as integration by parts or partial fraction decomposition. However, substitution can often simplify the process of solving integrals and make them more manageable.
