Represent the following inequalities on a single graph
In summary: This can already be put on the graph?First, let's look at the inequality:4y\le12-3(0)The boundary will be the corresponding line:4y=12-3(0)So, we need to graph this line, and an easy way is to fivide through by 12 so that it is in the two-intercept form:\frac{y
ai93
54
\(\displaystyle 3x+4y\le12\)
\(\displaystyle 3x+y\ge3\)
\(\displaystyle y\ge-1\)
I understand the how to plot these on a graph, just not sure how to solve these inequalities!
Do you have to solve for x or y?
Mathematics news on Phys.org
When you plot the 3 lines corresponding to the 3 inequalities, you should find that the triangular region bounded by the lines (including the boundaries because the inequalities are weak) forms the solution set.
I thought you would have to solve the inequalities first?
Each inequality will have as its solution part of the $xy$-plane. That part of the plane where the three solutions all intersect will be the solution to the system of inequalities, and you should find this in the region bounded by the 3 lines corresponding to the 3 inequalities.
We have to solve for \(\displaystyle y\) to determine the linear equations that serve as boundaries for the described region.
Would this be right?
3x+4y≤12
4y\(\displaystyle \le\)12-3(0)
y\(\displaystyle \ge\)3
3x+y\(\displaystyle \ge\)3
y\(\displaystyle \ge\)3-3(0)
y\(\displaystyle \ge\)-1
\(\displaystyle 3x+4y=12\)
\(\displaystyle \frac{x}{4}+\frac{y}{3}=1\)
Hence, we know the points $(4,0)$ and $(0,3)$ are on the line. Plot these points and then draw the line through them. Then, if we use the origin as a test point, we see that:
\(\displaystyle 3(0)+4(0)\le12\)
is true, so we know we want the points below this line (on the same side of the line as the origin). Can you use this same technique for the second inequality to determine its solution?
FAQ: Represent the following inequalities on a single graph
What does it mean to represent inequalities on a single graph?
Representing inequalities on a single graph means graphing multiple inequalities on the same coordinate plane. This allows us to visually compare and analyze the relationships between the inequalities.
How do you graph inequalities on a single graph?
To graph inequalities on a single graph, we first need to graph each inequality separately on the same coordinate plane. Then, we shade the regions that satisfy each inequality and determine the overlapping region, which represents the solution to the system of inequalities.
What is the purpose of representing inequalities on a single graph?
The purpose of representing inequalities on a single graph is to visually analyze the relationships between multiple inequalities. This can help us determine the possible solutions and make comparisons between the inequalities.
Can you represent any type of inequality on a single graph?
Yes, any type of inequality can be represented on a single graph as long as it can be graphed on a coordinate plane. This includes linear, quadratic, and exponential inequalities.
How can representing inequalities on a single graph be useful in real-world applications?
In real-world applications, representing inequalities on a single graph can help us model and solve various problems involving inequalities. For example, it can be used to determine the optimal production levels for a company based on cost and revenue constraints, or to analyze the relationship between income and expenses in personal financial planning.
