Representations of SU(3) Algebra
In summary: Expert Summarizer. In summary, the conversation discusses the 10-dimensional representation R3,0 of A2 and its relationship to the LC[SU(2)] subalgebra. The representation is reducible and can be broken down into smaller, irreducible representations of the subalgebra. The weights of the representation can be expressed as a linear combination of the subalgebras, and the weight diagram will vary depending on the chosen root.
dman12
I'm trying to figure out this question:
"Show that the 10-dimensional representation R3,0 of A2 corresponds to a reducible representation of the LC[SU(2)] subalgebra corresponding to any root. Find the irreducible components of this representation. Does the answer depend on the particular root chosen?"
So I am happy finding the decuplet of A2, which is just complexified L[SU(3)]. You get a triangle of the 10 weights, which are two dimensional due to the fact that the Lie algebra is rank 2.
But I don't get how you can view this as being a reducible representation of complexified L[SU(2)]. The weights of L[SU(2)] representations are one dimensional so how can we build a two dimensional weight system from them?
Any guidance on how to go about this question would be much appreciated!
Thank you for your question. I understand your confusion regarding the representation of A2 and its relationship to the LC[SU(2)] subalgebra. Let me try to explain it in a simpler way.
Firstly, it is important to note that the representation R3,0 of A2 is a 10-dimensional representation, meaning it has 10 different states or "weights". These weights are actually 2-dimensional, not 1-dimensional as you mentioned. This is because the representation is 10-dimensional, not 10 copies of a 1-dimensional representation.
Now, the LC[SU(2)] subalgebra corresponds to a root in A2. This root can be represented by a vector in 2-dimensional space. For example, let's say the root is (1,0), then this corresponds to the LC[SU(2)] subalgebra that contains the elements [Jz, J+] and [Jz, J-]. Similarly, if the root is (0,1), then the subalgebra contains [Jx, J+] and [Jx, J-].
The key point here is that the weights of the representation R3,0 can be expressed as a linear combination of these two subalgebras. This means that the representation R3,0 is actually a reducible representation, as it can be broken down into smaller, irreducible representations of the LC[SU(2)] subalgebras.
To find the irreducible components of this representation, you can use a technique called "weight diagrams". This involves drawing a diagram with the weights as points and connecting them with lines to show how they can be decomposed into smaller representations. The answer to whether this depends on the particular root chosen is yes, as the weight diagram will be different for different roots.
I hope this helps to clarify the concept for you. Please let me know if you have any further questions or need more guidance. Good luck with your studies!
Related to Representations of SU(3) Algebra
1. What is SU(3) Algebra?
SU(3) Algebra is a mathematical framework used to describe the symmetries of certain physical systems, particularly in nuclear and particle physics. It is a type of Lie algebra, which is a branch of mathematics that deals with continuous groups and their representations.
2. How is SU(3) Algebra represented?
SU(3) Algebra is typically represented using a set of 8 generators, which are mathematical operators that generate the symmetries of the system. These generators are usually written as 3x3 matrices, and they can be combined in various ways to form a basis for the entire algebra.
3. What are the applications of SU(3) Algebra?
SU(3) Algebra has many applications in theoretical physics, particularly in the study of subatomic particles and their interactions. It is used to describe the behavior of particles such as quarks and gluons, and has been instrumental in developing the Standard Model of particle physics.
4. What are the key features of SU(3) Algebra?
One of the key features of SU(3) Algebra is its use of complex numbers, which allows for a more complete description of physical systems. It also has a special type of symmetry known as "chirality", which refers to the way certain particles behave differently from their mirror image counterparts.
5. How does SU(3) Algebra relate to other Lie algebras?
SU(3) Algebra is part of a larger family of Lie algebras known as the "special unitary group". It is also closely related to other algebras such as SU(2), which is used to describe the symmetries of the proton and neutron, and SU(4), which is used in the study of nuclear forces.
  • Topology and Analysis
  • Linear and Abstract Algebra
  • Beyond the Standard Models
