B Reprise: Calculate the distance between two points without using a coordinate system
The discussion centers on calculating the distance between two points A and B using distances to three non-collinear reference points, without relying on a traditional coordinate system. A specific configuration, where the reference points form a right-angled triangle, allows for the calculation of distance using the distances from A and B to these points. The approach utilizes Pythagorean triples, eliminating the need for angles or perpendiculars. The concept of trilateration is highlighted as relevant, particularly in engineering contexts, while acknowledging the limitations of this method as a coordinate system. The exploration of this method offers new insights into the relationship between distances and coordinates.
Trysse
About two years ago I had a thread here, where I was looking for a way to calculate the distance between two points A and B on a plane when the following information is given:
  • The distances of the points A and B to three arbitrary (but non-colinear) reference points.
  • The distances between the three reference points.
https://www.physicsforums.com/threa...ing-a-coordinate-system.1014046/#post-6622205
Despite some helpful input, the thread did not get me the answer I was hoping for. So I let the problem rest for a while. Only recently have I come back to this problem. Again I did not find a universal solution for any arbitrary set of reference points. However, this time I have found that I can calculate the distance AB if the three reference points have a specific configuration:
If three reference points O, X and Y form a right-angled triangle, I can calculate the distance between the two points A and B from the distances AO, AX, AY, BO, BX and BY. The right angle XOY can be realized using Pythagorean triples so I don't need to think about constructing right angles.
For the calculation of distance and coordinates on a plane and in space see the following Geogebra models. The calculated distance is called AtoB in both files:
What I find nice about this approach, is that I can also calculate cartesian coordinates for points without the need for infinite axes and with only distances (i.e. no angles or directions or perpendiculars and no need to calculate roots (at least for the coordinates)). It has given me a new perspective on cartesian coordinates and the relation between coordinates and invariant distances. I thought this is quite neat!
The related principle is trilateration https://en.wikipedia.org/wiki/Trilateration
From what I have found online this seems to be of more interest for engineering than for geometry/math. https://www.sciencedirect.com/topics/engineering/trilateration
So, although I am no longer looking for a general solution, if you have one, let me know.
Mathematics news on Phys.org
I guess one interesting thing to think about - a coordinate system is just a way of assigning numbers that uniquely identifies each point in the plane. Cartesian coordinates and polar coordinates are the two best known ones, but a triple of distances from three specified points is just as validly a coordinate system on its own.
It's kind of a bad one, because as you observed it's really hard to tell where two points are in relation to each other just from their coordinates, but it's still a coordinate system.
Likes FactChecker and PeroK
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
