Repulsion between two small spheres
  • Thread starter Thread starter objective33
    Repulsion Spheres
The discussion focuses on calculating the electric repulsion force between two small spheres, each with a deficit of 1.0 x 10^8 electrons, separated by 1.0 m. The relevant equations include the charge of an electron (1.602 x 10^-19 C) and the Coulomb's law formula for force. The calculated force of repulsion is confirmed to be 2.3 x 10^-12 N, aligning with the textbook answer. Participants clarify the use of constants and the proper application of formulas to arrive at the solution. The discussion emphasizes the importance of correctly applying physics principles to solve the problem.
objective33
Calculate the force of electric repulsion between two small spheres placed 1.0 m apart if each has a deficit of 1.0 x 10^8 electrons.
N = q/e
qe = mg
q = mg / e
q = mgr / Vb
e = 1.602 x 10^-19 C.
k = 9 x 10^9 - not sure if relevant or not.
Fe = qe
Answer ( as stated in the textbook): 2.3 x 10^-12N
Fe = qe?
r = 1. 0 m
e constant used
g = 9.8 N/kg?
Fe = (1.0 x 10^8 C)( 1.6 x 10^-19 C)x (1.0m/9.8N/kg) = 1.63 x 10^-12 N.
Through my reasoning, I found the answer.
Charge of one electron = 1.602 x 10^-19 C
Charge of a sphere = 1.602 x 10^-19 x 1.0 x 10^8 C
F = (1/4piÈ) Q1Q2/d^2
(1/4piÈ) is a constant equal to 9 x 10^9
F = 9x10^9 x (1.602x10^-11) x (1.602x10^-11) / 1
F = 2.3 x 10^-12 N
9K
