I Request for an example of minimum energy principle (thermodynamics)
The minimum energy principle indicates that a system at constant entropy and volume minimizes internal energy at equilibrium. An example discussed involves the free expansion of a gas, where the gas occupies the entire available volume, demonstrating that entropy increases with volume. The relationship between internal energy and entropy is explored, particularly how the minimization of thermodynamic potentials can determine equilibrium states. The conversation emphasizes the need for examples that illustrate the application of the minimum energy principle in thermodynamics. Understanding these principles enhances comprehension of equilibrium states in various systems.
Simobartz
Summary: Request for an example of minimum energy principle usage
The minimum energy principle states that, for a system at constant entropy, volume and other extensive quantities, the internal energy is minimized at equilibrium. Can you give me an example in which, using this principle, is it possible to determine the equilibrium state of the system?
Science news on Phys.org
I can think of a couple of examples offhand. What searching have you been doing so far on this question? Is it for schoolwork?
Hi, it's for my personal understanding, no schoolwork
I've seen an example (it is written below) in which the principle of maximum entropy is used to determine the state of equilibrium of a system and, since the minimization of the proper potential at equilibrium is correlated to the principle of maximum energy, i thought it would be nice to think at some analogous examples involving thermodynamic potentials. So, examples in which minimization of the proper potentials is used to find the equilibrium state.
To start with I've tried to figure out an example involving internal energy for constant volume and entropy but i have difficulty with the constant entropy require.
The examples in which principle of maximum entropy is used to determine the state of equilibrium of a system: consider the free expansion of a gas in a volume ##V##. Will the gas occupy the entire available volume? The answer is, of course, yes.
Indeed we have ##dU=TdS-pdV=0## from which ##dS/dV=P/T>0##. So the entropy increases with the volume and since the equilibrium maximize the entropy it also maximize the volume.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
