Required Bolt Torque to Induce Given Stress
In summary, the person is having trouble determining the required torque to apply to a bolt in order to reach 75% of its yield strength. They ask about the relationship between applied torque and tensile stress and are advised that controlling torque alone is not a reliable method. More accurate methods, such as load indicating washers and measuring bolt elongation, are suggested for critical applications. For less critical applications, there are online resources available for calculating torque based on various factors.
BertSmurf
Hi, I have a problem calculating the required torque that needs to be applied to a bolt.
I need to torque the bolt to a maximum of 75% of the yield strength of the bolt (which I have worked out)
However I am having trouble figuring out what torque will actually apply this stress to the bolt...
What is the relationship between applied torque and induced tensile stress on the bolt?
What's your application? Tell us more and you'll get a better answer.
But in general you can't do what you're trying to do (a known fraction of yield strength) just by controlling the torque - nearly all the applied torque goes to overcoming friction, so even a small uncertainty in the friction between male and female threads and under the head of the bolt means a large uncertainty in the tension of the bolt. Instead, for really critical applications you have to use load indicating washers, measure the actual elongation of the bolt, go with angle tightening techniques, and other methods that more directly measure the strain in the bolt.
If your application is bit less critical than, for example, connecting rod bolts in a Formula One racing motor there are a number of online resources that will give a close-enough answer for various combinations of materials, thread pitch, bolt diameter, thread lubrication.
That's a pretty good answer, Nugatory.
:biggrin:
FAQ: Required Bolt Torque to Induce Given Stress
What is "Required Bolt Torque to Induce Given Stress"?
"Required Bolt Torque to Induce Given Stress" is a term used in engineering to refer to the amount of force or torque needed to apply to a bolt in order to achieve a specific stress level. This is an important factor in designing and assembling structures, as it ensures that the bolts are properly tightened and can withstand the intended load.
How is the required bolt torque calculated?
The required bolt torque is calculated using a formula that takes into account the material properties of the bolt, the size and thread pitch of the bolt, and the desired stress level. This formula is often provided by bolt manufacturers or can be found in engineering handbooks and manuals.
Why is it important to use the correct required bolt torque?
Using the correct required bolt torque is crucial to ensure the structural integrity and safety of a building or machine. If the bolt is not tightened enough, it may come loose and fail under load. On the other hand, if the bolt is over-tightened, it can lead to bolt failure, distortion of the material, or damage to the surrounding structure.
Are there any factors that can affect the required bolt torque?
Yes, there are several factors that can affect the required bolt torque, such as temperature, surface conditions, lubrication, and bolt length. These factors can impact the friction between the bolt and the mating surfaces, which in turn affects the amount of torque needed to achieve the desired stress level.
Can the required bolt torque change over time?
Yes, the required bolt torque can change over time due to factors such as material creep, thermal expansion, and settling of the structure. It is important to periodically check and re-torque bolts to ensure they are still tightened to the appropriate level and can withstand the intended load.
