I Requirement of Holonomic Constraints for Deriving Lagrange Equations
The discussion centers on the necessity of holonomic constraints for deriving Lagrange equations from d'Alembert's principle. It highlights that the transition to the equation involving partial derivatives of the Lagrangian requires the assumption of holonomic constraints, as non-holonomic constraints lead to virtual displacements that may not be perpendicular to the body's trajectory. The conversation suggests that while holonomic constraints simplify the derivation, non-holonomic constraints can also be incorporated effectively if treated correctly in configuration space. Participants note that extensive discussions on this topic, including vakonomic dynamics, can be found in the forum. Understanding the mathematical connection between constraints and virtual displacements is crucial for grasping the derivation process.
deuteron
TL;DR Summary
Why is it required for the constraints to be holonomic to derive the Euler-Lagrange equations of motion?
While deriving the Lagrange equations from d'Alembert's principle, we get from $$\displaystyle\sum_i(m\ddot x_i-F_i)\delta x_i=0\tag{1}$$ to $$\displaystyle\sum_k (\frac {\partial\mathcal L}{\partial\ q_k}-(\frac d {dt}\frac {\partial\mathcal L}{\partial\dot q_k}))\delta q_k=0\tag{2}$$
However, from the above step, we get to the below step only after assuming holonomic constraints:
$$(\frac {\partial\mathcal L}{\partial\ q_k}-(\frac d {dt}\frac {\partial\mathcal L}{\partial\dot q_k})=0.\tag{3}$$
Why is it that we have to assume holonomic constraints for that transition? My guess is that it has something to do with that if the constraints are not holonomic, then the virtual displacement are not always perpendicular to the trajectory of the body, but I can't see the mathematical connection between these.
There is no restriction to holonomic constraints. You can also treat non-holonomic constraints. If done right, i.e., as a constraint on the "allowed" variations of the trajectories in configuration space, you get the same equations as from d'Alembert's principle. We have a lot of discussions on this in this forum. Just search for "vakonomic dynamics" ;-).
Likes PeroK and deuteron
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
