Research Guidance on Tropical Cyclones (Hurricanes)
In summary, undergraduate student is researching wind force of Hurricane Katrina. They want to study the wind force only and have a process but do not know if its valid. They would like to use a program to transform data points into a topography graph and apply a force to reduce the wind force.
Selfless_Gene
Hello,
I am undergraduate student doing research and I am studying hurricane Katrina my completed math course is Calculus 3 which is up to Vector calculus. For my research I want study only wind force of the hurricane Katrina and I have a process but I want to know if its valid and what program I could use to accomplish this.
Process:
1. Collect the data on lat and long of path of the hurricane and plot the wind speed (velocity ) at those long. lat. points .
2. Once I input my data I want to obtain a vector function that describes the wind force.
3. Then i would like to transform several points on the path into a topography graph where we can see color indicators of strong winds.
4. Finally, I want apply a force in this path that can reduce the wind force and obtain a function describing the wind force.
Thank You for your time
You have given a good overview however to really solve the problem you'll need to know the force level and extent of the hurricane in addition to its path.
If you recall the lat/lon of the hurricane will be with respect to its eye. However, the eye of the hurricane has very low to zero wind speed.
Hurricanes also have a 3D structure where the winds are different at different heights. There is a water/rainfall component and a spinoff tornado component to be concerned with too.
Here's a more detailed model which I realize is beyond what you want to do but may give you some insight as to what you'll need in your model:
https://www.casact.org/education/rpm/2015/handouts/Paper_4071_handout_2487_0.pdf
and this site:
http://www.hurricanescience.org/science/forecast/models/modeltypes/dynamicalmodels/
and this site for 3D modeling:
http://www.soest.hawaii.edu/met/Faculty/businger/courses/notes200/15HurricaneStructure.pdf
So I guess you get to pick and choose what you want to model.
What programming will you be using? Matlab or Java...
and this site:
Thank you for your response and feedback it was very helpful. I've been using mathematica but it requires programming knowledge and its been diffcult for me to understand. I am going to look into MAT LAB now. Is there any program you recommend? I don't have the data of force level but the speed of the hurricane at that specific points of lat and long.
Also may i have your insights on a new plan i am proposing
1. create a multivariable function from f(lat, long) that describes the hurricanes path during time interval.
2. Use the multivariable function to create a countor graph that shows how the wind is moving over time.
3. Create a opposing multivariable function. (this portion is confusing I've never attempted this )
Does my steps make sense are they valid?
Thank You
If MATLAB is available for you to use, it is excellent. If you are on a limited budget or want to use a statistical package that is easily available, then you should consider R. It is free and well respected. There are R packages for geographic plots (see https://cran.r-project.org/doc/contrib/intro-spatial-rl.pdf )
Download freemat from the SourceForge website:
http://freemat.sourceforge.net/
Freemat is an open source Matlab clone mimicing core Matlab capability. I’ve used it a lot for quick plots and calculations. Matlab though comes with many toolkits that make life easier in certain computational domains like modeling and simulation,
There’s also Julia and the notebook interface from the anaconda distribution. Julia is very similar to Matlab but is open source and works well with other modeling languages and tools. There is a charting library as well.
Check this site for details:
https://lectures.quantecon.org/jl/
Related to Research Guidance on Tropical Cyclones (Hurricanes)
1. What are the main causes of tropical cyclones (hurricanes)?
Tropical cyclones, also known as hurricanes or typhoons, are caused by warm ocean waters, atmospheric instability, and favorable atmospheric conditions. The combination of these factors leads to the formation and intensification of these storms.
2. How are tropical cyclones (hurricanes) classified and named?
Tropical cyclones are classified and named based on their wind speed and location. The Saffir-Simpson Hurricane Wind Scale is used to classify hurricanes into five categories, with category 5 being the most intense. In the Atlantic and Eastern Pacific, hurricanes are named from a pre-determined list of names. In the Western Pacific and Indian Ocean, they are named by the Joint Typhoon Warning Center.
3. How do scientists track and predict the path of tropical cyclones (hurricanes)?
Scientists use a variety of tools, such as satellites, aircraft, and buoys, to track and monitor tropical cyclones. They also use computer models to predict the path and intensity of these storms. These models take into account various atmospheric and oceanic conditions to make a forecast.
4. What are the potential impacts of tropical cyclones (hurricanes)?
Tropical cyclones can have a range of impacts, including strong winds, heavy rainfall, storm surge, and tornadoes. These storms can cause extensive damage to infrastructure and property, as well as loss of life. They can also result in power outages, flooding, and disruptions to transportation and communication systems.
5. What can individuals and communities do to prepare for tropical cyclones (hurricanes)?
It is important for individuals and communities to have a plan in place for how to respond to a tropical cyclone. This can include creating an emergency kit, securing loose items outdoors, and knowing evacuation routes. It is also important to stay informed and follow the guidance of local authorities in the event of a storm.
  • STEM Academic Advising
  • STEM Career Guidance
