Research on HV to UHV vacuum gauge and controller build (Amateur scale)
  • Thread starter Thread starter Ducatidragon916
    Substitution
The discussion revolves around building a High Vacuum system using an outdated Leybold Heraeus Pirani Gauge controller (TM120) and the challenges faced in obtaining technical information and compatible gauge tubes (TR112). The user has reached out to Leybold for manuals and schematics but received limited support, as the products are obsolete. They are exploring the possibility of using gauge tubes from other manufacturers that may be compatible with the TM120 controller. The user notes that the Pirani Gauge's design is relatively simple, involving a Wheatstone bridge circuit, and seeks feedback or experiences from others who have retrofitted similar systems. Overall, the aim is to find alternative solutions to utilize the controller effectively despite its discontinued status.
Ducatidragon916
How did you find PF?: Looking for Circuits on Pirani Gauges
I am in the process of building a High Vacuum system and obtained an outdated Pirani Gauge controller TM120 on ebay. The unit is from Leybold Heraeus company and is built with quality. I contacted them on information on the manuals and on the Gauge tube itself. They sent me various pdf files but none provided a schematic or any pinouts on either the controller unit (TM120)or the Gauge Tubes (TR112).
Tried searching on ebay on the Gauge tubes Tr111 or Tr112 but could not find any. I am assuming that it might be possible to use an existing gauge tube from a different manufacturer to the controller and make it work. Tried to contact Leybold to ask if this were possible and they sent me a current catalog of new controllers (unsupportive of legacy products and pushing new ones is their biz motto) . They said that both units are obsolete etc.
It is a very nice controller and it would be a shame not to use it considering I purchased from ebay at a very cheap price (buyer beware of obsolete electronics not supported by manufacturers).
My thoughts are that Pirani Gauges are not that complicated and looking at the circuit it provides a 12V dc regulated power output with a set of precision resistors in the controller. The pdfs provided on the Tr111/Tr112 shows a possible Wheatstone bridge circuit in the gauge head with a separated vacuum sense tube that plugs into the overall gauge head.
So I am trying to locate other brands with the same type of configuration to determine the pinout and the possible substitution of other gauge tube sensors from other manufacturers to be used with the unit. It is a passive unit and not active since all the voltages and controlling circuits are in the controller. If anyone knows of or has retrofitted or modified a pirani gauge such as this or has additional information it would be greatly appreciated!
Looking forward to any feedback on the subject. I provided the manual that Leybold sent me on the gauge tubes. I also have the manual on the controller unit TM120 if anyone is interested.
I have learned that Leybold discontinued the Controller TM120 and the Gauge Tube Tr112 because the Gauge tube heater wire would break easily even when placed on the shelf very fragile. So has anyone ever created or modified a pirani tube to work on other manufactured controllers? Any ideas or thoughts?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
