Residue theorem for integral of real sinusodial function
In summary: In the example you gave, the pole at z = 2 is not on the inside of the circle contour, so the integral would be 2*pi*i instead of 0.
MadMax
99
I've seen a few examples but don't understand how the contour is chosen.
We use the substitution
[tex]z=e^{i \theta}[/tex]
If the integral is over -pi to pi, or over 0 to 2*pi, then the contour is the unit circle centred on the origin.
My questions:
1.) Why?
2.) What would the contour be if we were integrating over 0 to pi?
My attempts at answers:
1.) Is it because the subtitution we use is the usual parameterization of the unit circle? (I read that somewhere but to be honest I don't really understand what it means). Or is it a full circle because we are integrating over a full circle (0 to 2*pi) in the original limits of integration? In which case why is it a unit circle, why couldn't its radius be larger or smaller? How do we chose the radius of the circle contour?
2.) Would it be a unit semi-circle centred on the origin? If so which 2 quartiles of the imaginary plane would it cover? Or would it still be a unit circle centred on the axis?
Any answers/help/hints/tips would be much appreciated. Thanks.
Are you familiar with the Cauchy Integral Theorem?
Yes I think. It tells us that any integral over a closed contour in the complex plane is equal to zero if the function is regular on or within that contour. If there are singularities (poles) within the contour then we apply the residue theorem and find the value of the integral equal to 2*pi*i * [sum of residues of the poles]. Right?
All very well, but some integrals have several poles, and depending on which contour you choose you may or may not enclose these singularities. You have to choose a contour that is regular at all points for that function. But in all the examples I looked at they chose the unit circle centred on the radius, and in one of them this meant the pole at z = 2 wasn't enclosed, but they could have chosen a circle of radius 3 or 4 or even infinity and the function would still be regular at all points on the contour. I'm confused.
Thanks.
The integral theorem essentially proves that (provided there are no poles in between them) two contour integrals are going to have the same value. So the result will be the same if r=1 or if r=3, provided you're not changing what poles are on the inside.
FAQ: Residue theorem for integral of real sinusodial function
What is the residue theorem for an integral of a real sinusoidal function?
The residue theorem is a mathematical theorem that states that the integral of a real sinusoidal function over a closed contour can be calculated by summing the residues of the function at its singular points within the contour.
How is the residue theorem used in complex analysis?
The residue theorem is an important tool in complex analysis, as it allows for the evaluation of complex integrals by considering singular points of a function. This makes it easier to evaluate complex integrals that would otherwise be difficult to solve.
What is a singular point in the context of the residue theorem?
A singular point is a point where a function is not well-defined or has a discontinuity. In the context of the residue theorem, singular points are crucial as they contribute to the final value of the integral through the calculation of residues.
Can the residue theorem be used for all types of integrals?
No, the residue theorem is specifically used for integrals of real sinusoidal functions. It cannot be applied to integrals of other types of functions such as exponential or polynomial functions.
What are some practical applications of the residue theorem?
The residue theorem has many practical applications in physics, engineering, and other scientific fields. It is commonly used in the analysis of electric circuits, signal processing, and fluid dynamics. It also has applications in the calculation of statistical physics quantities such as partition functions and correlation functions.
