Residue Theorem with real zero
In summary, using the residue theorem, the integral \int_{0}^{\infty} \frac{\cos(\pi x)}{1-4x^2} dx can be rewritten as \frac{1}{2} \int_{-\infty}^{\infty} \frac{e^{i \pi x}}{1-4x^2} dx, which can then be completed in the upper half-plane. This results in a non-zero residue, giving an evaluation of \pi/4 for the integral.
DCN
Find [tex]\int_{0}^{\infty} \frac{\cos(\pi x)}{1-4x^2} dx[/tex]
The residue theorem
The residue of this function at $$x=\pm\frac{1}{2}$$ is zero. Therefore shouldn't the integral be zero, if you take a closed path as a hemisphere in the upper half of the complex plane? Yet the integral evaluates to $$\pi/4$$
I am completely lost.
The residue theorem
You cannot complete the integral along a semicircle in the upper half-plane because the function ##\cos(\pi x)## grows exponentially large when you let the imaginary part of ##x## go to infinity. However, you can instead write the integral as
[tex] I = \frac{1}{2} \int_{-\infty}^{\infty} \frac{\cos(\pi x)}{1-4x^2} \, dx = \frac{1}{2} \int_{-\infty}^{\infty} \frac{e^{i \pi x}}{1-4x^2} \, dx [/tex]
because the imaginary part of the second integrand is an odd function, which integrates to zero.
That last form can be completed in the upper half-plane, and when you do that the residues do not vanish.
Related to Residue Theorem with real zero
1. What is the Residue Theorem with real zero?
The Residue Theorem with real zero is a mathematical concept used in complex analysis to evaluate integrals. It states that if a function has a pole of order 1 at a real zero, then the residue at that zero is equal to the limit of the function as the variable approaches that zero.
2. How is the Residue Theorem with real zero useful in solving integrals?
The Residue Theorem with real zero allows for the evaluation of complex integrals by finding the residues at the poles of a function. This simplifies the integration process and can be used to solve a wide range of integrals.
3. Can the Residue Theorem with real zero be applied to functions with multiple poles?
Yes, the Residue Theorem with real zero can be applied to functions with multiple poles. In this case, the theorem states that the sum of the residues at each pole is equal to the integral of the function over a closed curve.
4. What is the relationship between the Residue Theorem with real zero and the Cauchy Residue Theorem?
The Residue Theorem with real zero is a special case of the Cauchy Residue Theorem, which is a more general version of the theorem. The Cauchy Residue Theorem states that the sum of the residues of a function at its poles is equal to the integral of the function over a closed curve.
5. Are there any limitations to using the Residue Theorem with real zero?
The Residue Theorem with real zero can only be applied to functions that have a pole of order 1 at the real zero. If the function has a pole of higher order, then the theorem cannot be used to evaluate the integral. Additionally, the function must be analytic on the closed curve over which the integral is being evaluated.
