Resistance and Radii Relationship
The resistance of wire A is stated to be four times that of wire B, leading to a discussion about calculating the ratio of their radii. It is clarified that if both wires have the same cross-sectional area, their radii must also be equal, resulting in a ratio of 1:1. Participants emphasize the need for accurate problem details and suggest that the original question may have been misinterpreted. The importance of providing complete information for a proper solution is highlighted. Ultimately, the conclusion is that the radii ratio is fixed at 1:1 if the wires share the same cross-sectional area.
anshuman3105
The resistance of wire A is four times the resistance of wire B. Calculate the ratio of the radii of the wires
Hello anshuman3105. Welcome to PF !
What have you tried?
Where are you stuck?
You need to show some effort towards obtaining a solution -- according to the rules of this Forum.
By the way, you n would need more information to solve this problem.
Please state the problem word for word as it was given to you.
Then give an attempt at a solution.
I just don't know... :(
Please help.
Please help.
Are the wires the same length?
Are they made of the same material?
the wires have the same material and same cross-sectional area
anshuman3105 said:
...same cross-sectional area
Are you sure about this?
Yaaa...sure..!
anshuman3105 said:
Yaaa...sure..!
If they have the same cross-sectional area then they have the same radii and the ratio is fixed at 1:1. Any other information or details would be irrelevant. It therefore seems likely that you have either misinterpreted the question or are not providing the true problem statement for reasons we can only guess at.
  • · Replies 24 ·
  • · Replies 30 ·
