- #36
Baluncore
2023 Award
- 15,557
- 9,309
Your original question hypothesised an infinite 2D plane with point charges. But current cannot flow in 2D, it requires 3D, so your model becomes a section through two circular conductors.
A current filament is a very thin thread of current. It is sometimes round with a finite radius, at other times it can be treated as being infinitesimally thin. Your simplest model requires conductors to be of circular section that can map to equipotentials.
Take any two parallel cylindrical conductors, of any radius ratio, and you can map them onto the equipotential circles of the field diagram. That makes much of the maths easier when it comes to fields, such as transmission line analysis.
The same happens in your model when two conductive discs or rings are placed on a plane in 2D. They make it trivial to plot the surrounding field as circles.
Where an electric field exists, a current will flow, the magnitude of the current is determined by the voltage divided by resistance. The equipotentials have the same pattern no matter what the resistivity of the infinite medium surrounding the conductors. Only the current flow is different.
