crashcat
- 45
- 32
Two different projects require me to understand the behavior of a basic signal wire at 20-100 kHz and also at 1.7-2.1 MHz. So I tried to go to basics and take, as a starting model, a single real wire say 18 AWG of pure Cu to make it simple and understand the frequency dependent impedance including the resistance, tiny capacitance, and tiny inductance.
I've found some "answers" but it's always just some handbook equations and not a real answer from basic principles. I am just struggling to find a source that actually derives it even though, practically, you would have to measure your wire at some point and can't derive the whole thing from first principles.
What even is the cause of straight wire capacitance? Some models act like it is a shunt to ground which means it should depend on how you install the wire, but that's usually called parasitic capacitance and is at least an order of magnitude smaller than typical wire capacitance. Do charges get trapped at grain boundaries inside the wire, or the weak dipole moment of some impurities or vacancies, or anyway it's something intrinsic to the wire? Or is it purely related to conduction and the real time delay of signals making it appear to have capacitance at higher frequencies? I can't even find basic stuff like this. Just some equivalent circuits with ESR and IR and this and that which aren't given on wire data sheets anyway so how do you build and understand the model?
