bucky3052
- 2
- 1
- TL;DR Summary
- How much does velocity of a fluid drop as it passes through a magnetohydrodynamic generator
I am attempting to derive equations of state for a flow loop that incorporates a magnetohydrodynamic (MHD) generator to extract energy from the working fluid, an ionized gas. I have been able to find the following equation to define the power output of the generator:
(where K is load factor, σ is conductivity, u is velocity, and B is applied magnetic field)
However, in order to complete my equations of state, I need to balance this power against the change in the fluid's enthalpy and pressure/velocity:
(where m is constant mass flow rate, h is specific enthalpy, and v is velocity [sorry for inconsistent variables])
Just from some basic reading, it seems like the fluid should have to "push" against some force as it goes through the MHD generator in order to produce power, which should reduce its velocity. If this is true and significant, I need to account for it in my equations of state, but I'm not sure how to model this
Is there a well-defined "resistance" force (opposing the direction of travel) experienced by the gas, or a way to quantify slowing through the MHD generator?
