osmax67
- 2
I have a 400 amp 0-40 volt dc supply, I need to heat a wire by wrapping it around two bronze/nickel pulleys 12" diameter , with one connected to the positive terminal of the supply and one to the negative. The wire being mild steel .148" diameter moving at a rate of 50' per second with the desired temperature being 400°f , 240" after coming off the second pulley in an controlled environment 80°f .How would you calculate the spacing between the positive and negative pulleys for varying speeds and diameter? Assuming the wires ambient temperature to be 80°f before it is heated and the pulleys have a controlled temperature of 120 °f..
