Resistance of a odd shaped conductor
The discussion revolves around calculating the resistance of an oddly shaped conductor using relevant physics equations. Participants emphasize the importance of understanding the relationship between current density (J), electric field (E), and resistivity (ρ) to derive the potential difference (V) across the conductor. One user suggests starting with the resistance formula R = V/I and integrating over the conductor's geometry, while noting that the radius (r) varies with height (z). Another participant expresses uncertainty about the integration process and the formulation of J as a function of z. The conversation highlights the complexity of applying standard equations to irregular shapes and encourages exploring different approaches to solve the problem.
jesuslovesu
http://img228.imageshack.us/img228/2536/physicsme1.th.png
I = \int \int J . dS
V = - \int E . dl
V = IR
I'm not really sure how to get started on this problem, generally I would start with Laplace's equation but due to its irregular shape, I don't think that I can use that for this situation.
J is a function the length of the shape, but not sure how to formulate it into something useful
Does anyone know how I can get started on this?
I(z) = \int_0^h \int_0^{2\pi} \mathbf{J}(z) z d\phi dz
Hi jesuslovesu,
Here are a couple of points that may help.
The resistance of an object is R=V/I. Here you can assume that there is a constant current coming in one side of the resistor and leaving the other (and they must be the same-do you see why?) So if you can find the potential difference across the resistor that gives that current you'll be done.
The resistivity relates the current density and the electric field by
<br /> \vec J = \frac{\vec E}{\rho}<br />
You say you found an expression for \vec J. How can you then find V?
Hey thanks for your reply, I've almost got it but I can't seem to quite get the last part.
So I say that J(z) = \frac{I}{\pi r^2}
V = - \int_0^h \frac{I dz}{\sigma \pi r^2}
\frac{I*h/(\sigma \pi r^2)}{I} = \frac{h}{\sigma \pi r^2}
I've almost got it but I don't quite know what to do with the 'r', I am not positive if my integral is correct since J is a function of z
I would have approached it differently, but either way should be valid. I would have started with the equation for the resistance of a fixed-area element:
R_i = \frac{\rho L}{A}
and integrated circular cross-sections of the conic section. Maybe give that approach a try...
r is a function of z. You have r(0) = a and r(h) = b
  • · Replies 18 ·
