Resistance of wire changes between tests?
In summary, a colleague showed me that using the Bio-Tek 601 Pro, I could send 10A through the failed wire and hence "fix" it somehow. He explained that a large current would somehow free the electrons and make the wire more conductive, reducing the resistance. I was not sure, but I've tested his theory and its true. When I checked the failed wire using a 10A current, the recorded resistance is lower. Then, when I bring the wire back to the 3M and test using a 1A current, it seems the resistance is now well under 0.2 ohm.
icekin
I've got a power cord on which I am testing the resistance of the Earth wire. I've used 2 different test machines, a MEM ELEC-3M and a Bio-Tek 601 Pro. The 601 can use 2 different test currents, 10A and 1A. The 3M uses only 1 test current, which is slightly less than 1A.
The minimum standard for a pass is a resistance lower than 0.2 ohm between the 2 ends of the Earth wire. The wire is 3 metres long. I normally use the 3M for testing. Sometimes, I get a wire that has more than 0.2 ohm and I usually declare it a fail. But recently, a colleague showed me that using the 601, I could send 10A through the failed wire and hence "fix" it somehow. He explained that a large current would somehow free the electrons and make the wire more conductive, reducing the resistance. I was not sure, but I've tested his theory and its true. When I checked the failed wire using a 10A current, the recorded resistance is lower. Then, when I bring the wire back to the 3M and test using a 1A current, it seems the resistance is now well under 0.2 ohm.
In addition, if I use the 1A current on the 601, I get a lower resistance reading versus using the 10A. I believe the machines, which are basically digital multimeters, simply divide the voltage across the ends of the wire by the current through the wire to get the measured resistance. In that case, why the difference in the measurement on the same test machine? I'd also appreciate if someone could tell me if my colleague's theory of more current fixing the wire is correct.
Copper wire does not need to have its electrons "freed", if that was possible. It has ample free electrons anyway.
Using a higher current in the wire might have a heating effect, but this would increase the resistance of the wire. It would dissipate 20 watts over a 3 M length, so it could get slightly warm if not hot.
It might be possible to get a temporary improvement in the contact resistance of the connection of the wire to the plug by this heating. Maybe the plug contacts expand and grip the wire more firmly.
You could check this by re-testing a wire after 20 minutes or so, when it has cooled down to room temperature.
If it returns to its previous resistance, then the effect is only temporary.
It seems unlikely that 10 amps would be able to weld the copper wire to the plug contacts, but I guess that might happen.
The actual power dissipated would only be around 2W at best. The green Earth wire in the power cord is only about 2mm thick approximately. Cross sectional area would then be 3.14 x 10^-6 square metres. Taking the resistivity of standard copper, the resistance comes to 0.0161 ohms. Power = R.(I^2) = 0.0161 x (10^2) = 1.61W
Power = I^2 * R
I= 10 A
R = 0.2 ohms
Power = 10 * 10 * 0.2 = 20 watts
Also, 2mm thick wire is roughly 12 gauge (about 0.16 ohms per 100 ft), which is rated for about 10 amps, so shouldn't heat up very much. Measuring small resistances takes some care. Unless you are doing a 4-wire measurement, contact resistances may be the biggest source of error.
vk6kro said:
Power = I^2 * R
I= 10 A
R = 0.2 ohms
This is correct if we assume that the measured resistance is correct. At the moment, due to the discrepancies between the 601 and the 3M, I am not even sure if the test equipment is correct. I thought calculating using the thickness, length and resistivity would be more foolproof in this case.
I've decided to try some further tests with the faulty and a brand new wire. Procedure as follows:
For each wire,
Step 1. Measure resistance on 3M
Step 2. Measure resistance on 601 at 1A
Step 3. Measure resistance on 601 at 10A
Step 4. Measure resistance on 601 at 1A
Step 5. Measure resistance on 3M
Record all 5 values. Repeat entire test at 15 min intervals.
The goal is to check and see whether the effect of the "fix" is purely temporary as vk6kro mentioned earlier. My colleague says its permanent. He says applying 10A make the wire "nice and soft" hence fixing it. I am not sure what he means by that because the melting point of copper is over 1000 degrees Celsius.
If someone knows of this experiment already done before, kindly post the link so that I may save some effort. Plus, my testing conditions are probably not perfectly ideal.
Why not measure the resistance at 10 amps, then don't turn it off, but keep recording it every 5 minutes to see how much it changes?
Try this with just a piece of the same wire and then with any plug that is normally on it.
I think you have an instrument problem or a procedural problem, because the resistance of copper does not have a memory of how it has been treated in the past.
I hope it doesn't, anyway.
Sounds like you need to take four wire resistance measurements. Most likely you're seeing more resistance in youo connections than is in the actual wire.
If these are newly fabricated cords, could there be some chemical residue from the process in the connections which might burn off with the higher currents?
It is also probably time to bring in some reliable multimeters to check the calibration of these instruments.
Put an ammeter in series with the test wire and see what actual currents are being produced.
Put a voltmeter across the wire to check the internal meter.
Calculate the resistance yourself to see if it agrees with the test instrument.
Related to Resistance of wire changes between tests?
What factors can affect the resistance of a wire between tests?
The resistance of a wire can be affected by several factors, including the material of the wire, the length and thickness of the wire, and the temperature of the wire. These factors can cause changes in the wire's conductivity and ultimately affect its resistance.
Why might the resistance of a wire change between tests?
The resistance of a wire can change between tests due to several reasons. One possible reason is that the wire may have been physically altered between tests, such as being stretched or bent. Another reason could be changes in temperature, which can affect the conductivity of the wire and thus its resistance.
How can we ensure consistent results when testing the resistance of a wire?
To ensure consistent results when testing the resistance of a wire, it is important to control the variables that can affect resistance. This can include using wires of the same material, length, and thickness, and keeping the temperature constant. It is also important to use accurate and calibrated measuring instruments.
What are some common methods for measuring the resistance of a wire?
Some common methods for measuring the resistance of a wire include using a multimeter, a Wheatstone bridge, or an ohmmeter. These instruments can provide accurate readings of the wire's resistance by measuring the voltage and current flowing through the wire.
How can we use the resistance of a wire to determine other properties, such as its length or cross-sectional area?
The resistance of a wire can be used to determine its length or cross-sectional area by using Ohm's Law, which states that resistance is directly proportional to length and inversely proportional to cross-sectional area. By measuring the resistance of a wire with different lengths or thicknesses, we can calculate these properties using the formula R = ρl/A, where ρ is the resistivity of the wire material.
  • Electrical Engineering
11K
