Resistance problem- combination circuit
In summary: Keep up the good work! In summary, the total resistance of the circuit is 57 ohms. This is calculated by solving for resistors connected in series and parallel using the given formulas and values.
adv
Question 3. Find the total resistance of the following circuit.
Formulas:
R= V/I
If the # of resistors connected in series is n, the equiv. resistor is given by
Rs = R1 + R2 +... + Rn
likewise with resistors connected in parallel,
1/Rp = 1/R1 + 1/R2 +... + 1/Rn
Given:
V0 = 120 V
R1 = 20 Ω
R2 = 22 Ω
R3 = 30 Ω
R4 = 27 Ω
R5 = 40 Ω
R6 = 20 Ω
R7 = 20 Ω
My attempt:
Applying Ohm’s Law to the entire circuit:
I0 = V0 / RT , where RT is the total resistance in the circuit
But since R3 and R4 are connected in series,
RS = R3 + R4
= 30 Ω + 27 Ω
= 57 Ω
Then RT1 and R7 are connected in parallel:
1/RP = 1/RS + 1/R7
= 1/57 + 1/20
= 20/1140 + 57/1140
= 77/1140 Ω
RP = 14.8 Ω
= 15 Ω
Solve five resistors R1, R2, RP, R5 and R6. These resistors are connected in series
RT = R1 + R2 + R3 + R4 + R5 + R6
= 20 Ω + 22 Ω + 15 Ω + 40 Ω + 20 Ω
= 117 Ω
Therefore, the total resistance of the circuit is 117 Ω.
I'm not sure I took the right approach. Any help would be appreciated. Thanks.
  • AliaDeVos-M17A1.doc
R2 and R5 are in series with R3 and R4. They should be included in the calculation of RS.
R2, R3, R4, and R5 are all in series
R8=R2+R3+R4+R5
R8 is parrallel to R7
1/R9=1/R8 + 1/R7
R9 is in series with R1 and R6
RTotal=R1+R9+R6
Here is the correction:
Since R2, R3, R4 and R5 are connected in series,
R8 = R2 + R3 + R4 + R5
= 22 Ω + 30 Ω + 27 Ω + 40 Ω
= 119 Ω
Then R7 and R8 are connected in parallel:
1/R9 = 1/R7 + 1/R8
= 1/20 + 1/119
= 119/2380 + 20/2380
= 139/2380 Ω
R9 = 17.1 Ω
= 17 Ω
Solve three resistors R1, R9 and R6. These resistors are connected in series
RT = R1 + R9 + R6
= 20 Ω + 17 Ω + 20 Ω
= 57 Ω
Therefore the total resistance of the circuit is 57 Ω.
I think this is correct now. Thank you Phlogistonian and Drdizzard. BTW, the relabeling of R8 and R9 was less confusing than Rs and Rp. I guess it was more consistant. Anywho, thanks!
That's correct the total resistance of the circuit is 57 ohms. I am glad I was able to help.
Related to Resistance problem- combination circuit
1. What is a "resistance problem" in a combination circuit?
A resistance problem in a combination circuit refers to a situation where the total resistance in the circuit is different from what is expected or desired. This can occur due to a variety of factors such as incorrect calculations, faulty components, or improper wiring.
2. How is the total resistance calculated in a combination circuit?
The total resistance in a combination circuit is calculated by adding together all the individual resistances in the circuit. This includes resistors in series, where the values are simply added, and resistors in parallel, where the reciprocal of each resistance is added and then the inverse of the sum is taken.
3. What is the relationship between voltage, current, and resistance in a combination circuit?
According to Ohm's Law, there is a direct relationship between voltage and current, and an inverse relationship between current and resistance. In a combination circuit, these relationships still hold true, but the calculations become more complex due to the presence of multiple resistors.
4. How do you troubleshoot a resistance problem in a combination circuit?
To troubleshoot a resistance problem in a combination circuit, it is important to first check all the calculations and ensure they are correct. Next, check all the components to make sure they are functioning properly. If these steps do not resolve the issue, then the wiring should be checked for any errors or loose connections.
5. How can resistance problems in combination circuits be prevented?
To prevent resistance problems in combination circuits, it is important to carefully plan and calculate the circuit before building it. Double-checking all calculations and using quality components can also help prevent issues. Additionally, regularly maintaining and checking the circuit for any faults can help catch and prevent resistance problems before they occur.
