Resistive force exerted on a sphere (air resistance)
alejo ortega
New user has been reminded to always show their work on schoolwork questions
The following expression gives the resistive force exerted on a
sphere of radius r moving at speed v through air. It is valid over a
very wide range of speeds.
Rc= 3.1× 10-4rv + 0.87r2v2
where R is in N, r in m, and v in m/s. Consider water drops falling under their own weight and reaching a terminal speed.
(a) For what range of values of small r is the terminal speed
determined within 1% by the first term alone in the expression for
R(v)?
(b) For what range of values of Iarger r is the terminal speed
determined within 1% by the second term alone?
(c) Calculate the terminal speed of a raindrop of radius 2 mm. If there were no air resistance, from what height would it fail from rest before reaching this speed?
i don´t understand the question
Well, let's start by typesetting that equation and using some guesswork to fix the typos:Now you need to bring something to the table. Show us some effort. How would we determine terminal speed given this formula for resistive force? (i.e. "Calculate the terminal speed of a raindrop of radius 2 mm").
And with a few more corrections:
Likes Lnewqban
ok ,
hello haruspex, this is a cuadratic ecuation
alejo ortega said:
ok ,
considering that if v is the terminal velocity, the resistive force is equal to weight
I equaled the first term to 1% of mg
3.1× 10-4rv = mg/100
and solve to r :
r= (10^2) mg/3,1v
alejo ortega said:
ok ,
and solve to r :
r= (10^2) mg/3,1v
but i believe that this proceeding its wrong :(
No, that’s a misunderstanding of the given information.
It is telling you that the first term gives you at least 99% of the value, with the quadratic term only contributing 1%.
