Resistive forces on a submarine?
In summary, to accurately determine the resistive forces of a submarine traveling at a constant velocity in sea water, one would need to conduct CFD modelling or use a force gauge to measure the amount of energy or power used. This can be done through computer simulations or physical testing, depending on the resources available.
K_Factor
Lets say I was going to build a submarine, how could I determine most accurately the resistive forces as it is traveling in sea water at a constant velocity. I need to know how much energy it would consume per km. Cant find anything about this online..
Thanks in advance!
You would probably determine the frcition forces from the amount of energy (or rather power) it used at constant speed.
If you were developing a submarine you would do CFD modelling in a computer or drag a model behind a boat with a force gauge - depending on how big a navy you are.
Related to Resistive forces on a submarine?
1. What are resistive forces on a submarine?
Resistive forces refer to the forces that act against the motion of a submarine, slowing it down or preventing it from moving in a certain direction. These forces include drag, buoyancy, and friction.
2. How do resistive forces affect the movement of a submarine?
Resistive forces can significantly impact the movement of a submarine by increasing the amount of energy required to move through the water and altering the trajectory of the submarine. They can also cause vibrations and noise, which can be detected by potential enemies.
3. What factors influence the magnitude of resistive forces on a submarine?
The magnitude of resistive forces on a submarine is influenced by various factors such as the shape and size of the submarine, the speed at which it is moving, the density and viscosity of the water, and external factors such as currents and waves.
4. How can resistive forces be minimized on a submarine?
To minimize resistive forces on a submarine, its design must be optimized for hydrodynamics. This includes having a streamlined shape, reducing surface roughness, and using propulsion systems that are efficient in reducing drag. Regular maintenance and cleaning of the hull can also help reduce resistive forces.
5. Can resistive forces cause damage to a submarine?
Excessive resistive forces can cause structural damage to a submarine, especially if it is moving at high speeds. The vibrations and noise caused by resistive forces can also affect the functioning of sensitive equipment on board. Therefore, it is important to carefully consider and manage resistive forces in submarine design and operation.
  • Mechanical Engineering
  • Other Physics Topics
  • Earth Sciences
16K
