Resistors in front of capacitors
In summary, the conversation discusses the arrangement of a power source, resistor, and capacitor in a circuit, and the reasons why the capacitor cannot be directly hooked up to the emf. It also explains the consumption of current and voltage in a capacitor and how it differs from resistors. The conversation also mentions the concept of energy storage and dissipation in capacitors, and the potential for energy to be radiated into space. The use of the Dirac delta function and the Heaviside step function is also discussed in relation to instantaneous changes in voltage and current.
vjk2
90
Most arrangements I've seen have a power source hooked up to a resistor hooked up to a capacitor. Like this
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capchg.html
Why? I mean, why can't we directly hook the capacitor to the emf?
sounds stupid, I know.
Also, resistors follow Ohms, V=IR in their consumption of current and voltage. How does a capacitor consume current and voltage?
You can.
But every 'emf' source will have a finite source resistance. The C will charge up v quickly but not instntly. RC is still the time constant.
The current flowing into a C depends upon the value of the series R. The Charge on the capacitor is related to the Voltage across it
Q = CV
where C is the capacity
The rate of charging (the current) depends upon the value of and voltage across the series resistor - hence the exponential shape of a charge or discharge curve.
A capacitor will not consume power (product of voltage and current) instead it stores energy in electrostatic form. If a capacitor is directly connected to a voltage source, it is charged up instantaneously (assuming ideal voltage source and capacitor). The current flow will be a spike at t=0, and voltage across c will be v at t=0.
That particular model will radiate an equal amount of energy to that which is stored 'in' the capacitor. I say that because there will be half C Vsquared stored in the energy but the emf will be V all the time. That would mean that, for conservation of Energy, the rest of the physical circuit must act as an antenna, appearing in series with the C to account for the other half of the energy supplied by the emf. There will be a burst of 'ringing' at some RF frequency, during which the energy will be radiated / dissipated into space.
It's another of those 'Irresistible Force and Immovable Object' scenarios for trapping the unwary student.:smile:
Ohh I didn't get it. To my small knowledge, once the capacitor charges to v, the current flow stops from the source and hence the power. So law of conservation of energy won't come into picture here. There is no compulsion for capacitor to radiate energy or the remaining circuit to act as antenna. The formula half c v squared just indicates energy stored in capacitor and there is no another half to be radiated into space. Clarify me if i am wrong.
You have shown a series RC circuit, the cap IS connected to the battery. It does not make any difference which order the components are in.
As for resistance, for caps and inductors we speak of the Impedance. The impedance is dependent upon the frequency.
Yes you're wrong. The net charge transferred to the capacitor during charging is Q=CV, which means that the net energy drawn from the supply is W = QV = CV^2. But this is exactly twice the energy stored on the capacitor therefore an equal amount (to that stored) is also lost. It's lost either in the series resistance (no matter how small) and additionally in radiation from the wires as the current oscillates in series resonance with the self inductance of the wires (in the case where the series resistance is sufficiently small.
BTW. Anyone who wishes to conceptualize circuits as having instantaneous changes in voltage and infinitely sharp spikes in current needs to be aware of the properties of the "Dirac delta function". In particular they should understand that it's ratio of mean squared value to mean value is infinite. They should understand that this means it is impossible to exist in nature and that approximations to it may therefore dissipate arbitrarily large energy into arbitrarily small resistances, even when the actual impulse value (area) is small.
I was referring to the model in the preceding post in which a capacitor was connected directly to an (ideal) emf source (zero series resistance, which is not possible). Energy has to go somewhere (the emf must be V, whatever current is flowing).
In the simple RC case, half the energy supplied by the source is dissipated in the series resistor. Except that there will always be a finite amount of energy radiated into space (very low for 'normal' component values, of course.
@uart
In this case we are more likely dealing with the results of the Heaviside (step) function, I think.
sophiecentaur said:
@uart
No. I was talking about the current, the derivative of the Heaviside step function. An impulse has unbounded energy per unit area (under curve), eg per unit charge in the case of current flow.
FAQ: Resistors in front of capacitors
What is the purpose of placing a resistor in front of a capacitor?
The resistor in front of a capacitor is used to limit the flow of current and control the voltage across the capacitor. This ensures that the capacitor charges and discharges at a consistent rate, preventing damage to the capacitor and other components in the circuit.
How does the value of the resistor affect the charging and discharging of the capacitor?
The value of the resistor determines the time constant of the circuit, which is the time it takes for the capacitor to charge or discharge to approximately 63% of its final value. A larger resistor value will result in a longer time constant, meaning the capacitor will charge and discharge more slowly.
Can a resistor be placed after a capacitor in a circuit?
Yes, a resistor can be placed after a capacitor in a circuit. However, this will affect the rate of discharge of the capacitor, as the resistor will be in series with the capacitor and limit the flow of current.
What happens when a resistor and capacitor are placed in parallel?
When a resistor and capacitor are placed in parallel, the capacitor will charge to the same voltage as the power source while the resistor will limit the flow of current. This creates a time delay as the capacitor discharges through the resistor, known as a RC time constant.
How do I choose the appropriate resistor and capacitor values for my circuit?
The values of the resistor and capacitor will depend on the specific circuit and its requirements. Generally, a larger resistor value will result in a longer time constant and slower charging/discharging of the capacitor. It is important to consider the voltage and current ratings of both components to ensure they can handle the demands of the circuit.
