I Resolve moment of inertia at an angle
To calculate the moment of inertia of a square lamina rotated at an angle about a vertex, it is suggested to split the shape into two components in the x-z and y-z planes. However, this method may lead to inaccuracies, and using a triple integral is recommended for precise calculations. The parallel axes theorem can be applied after determining the moments of inertia for the individual components. Clarification is sought on the appropriate circumstances for using the two planes method. Accurate moment of inertia calculations are crucial for understanding rotational dynamics.
curiousPep
Initially, I calculate the moment of inertia of of a square lamina (x-z plane). Thr this square is rotated an angle $\theta$ about a vertex and I need to calculate the new moment of inertia about that vertex.
Can I split the rotated square to two squares in the x-z plane and y-z plane to find the matrix of moment of inertia about x,y,z axis and then use the rotated shape and the parallel axes theorem to find the moment of inertia abou the vertex?
What I mean is resolving the the dark shape to two shapes (red and orange outline) and find the individual moment of inertia to find the moment of inertia of the dark shape
  • N.pdf
    N.pdf
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
