Resolve the Recursion of Dickson polynomials
In summary, the expression for Dickson polynomials can be proved using the recurrence relation and induction, where the base case is n=0 and n=1 and the inductive hypothesis is that it holds for n and n-1. However, the recurrence can also be solved directly to show that the resulting expression is of the required form.
pawlo392
I am trying to prove the expression for Dickson polynomials:
$$D_n(x, a)=\sum_{i=0}^{\lfloor \frac{n}{2}\rfloor}d_{n,i}x^{n-2i}, \quad \text{where} \quad d_{n,i}=\frac{n}{n-i}{n-i\choose i}(-a)^i$$
I am supposed to use the recurrence relation:
$$D_n(x,a)=xD_{n-1}(x,a)-aD_{n-2}(x,a)$$
I have tried to use induction to prove this, but I am having trouble. Here's what I have so far:
Base case: For ##n=1##, we have:
$$D_1(x,a)=x$$
which matches the expression for ##D_n(x,a)## when ##n=1##. So the base case holds.
Inductive step: Assume that the expression for ##D_n(x,a)## holds for some ##n \geq 1##. We want to show that it also holds for ##n+1##.
From the recurrence relation, we have:
$$D_{n+1}(x,a) = xD_n(x,a) - aD_{n-1}(x,a)$$
Substituting the expression for ##D_n(x,a)## and ##D_{n-1}(x,a)##, we get:
\begin{align*}
D_{n+1}(x,a) &= xD_n(x,a) - aD_{n-1}(x,a) \\
&= x\sum_{i=0}^{\lfloor \frac{n}{2}\rfloor}d_{n,i}x^{n-2i} - a\sum_{i=0}^{\lfloor \frac{n-1}{2}\rfloor}d_{n-1,i}x^{n-1-2i} \\
&= \sum_{i=0}^{\lfloor \frac{n}{2}\rfloor}d_{n,i}x^{n-2i+1} - \sum_{i=0}^{\lfloor \frac{n-1}{2}\rfloor}d_{n-1,i}ax^{n-1-2i} \\
&= \sum_{i=0}^{\lfloor \frac{n}{2}\rfloor}d_{n,i}x^{n-2i+1} - \sum_{i=1}^{\lfloor \frac{n}{2}\rfloor}d_{n,i-1}ax^{n-2i+1} \\
\end{align*}
Now, I am stuck here and not sure how to proceed. Can someone please provide some guidance or hints on how to continue with the proof? Thanks in advance.
If you do use induction, then your base case is to show that the result holds for [itex]n = 0[/itex] and [itex]n = 1[/itex], and your inductive hypothesis is that if the result holds for [itex]n[/itex] and [itex]n-1[/itex] then it holds also for [itex]n + 1[/itex]. That will invole some manipulation of binomial coefficient identities.
However, there may be an easier way. The recurrence [tex]
D_n(x,a) = xD_{n-1}(x,a) - aD_{n-2}(x,a)[/tex] subject to [tex]D_0(x,a) = 2, \qquad D_1(x,a) = x[/tex] is a constant coefficient linear recurrence for [itex]D_n(x,a)[/itex] in terms of [itex]n[/itex]. It is straightforward to solve this recurrence and show directly that the resulting expression for [itex]D_n(x,a)[/itex] is of the required form.
FAQ: Resolve the Recursion of Dickson polynomials
What are Dickson polynomials?
Dickson polynomials are a family of polynomials that are defined recursively. They are denoted as \( D_n(x, y) \) and are particularly notable in number theory and algebra. The first few are defined as follows: \( D_0(x, y) = 2 \), \( D_1(x, y) = x \), \( D_2(x, y) = x^2 - 2y \), and for \( n \geq 2 \), they can be defined using the recurrence relation \( D_n(x, y) = xD_{n-1}(x, y) - yD_{n-2}(x, y) \). These polynomials have applications in various areas including coding theory and cryptography.
How do you resolve the recursion of Dickson polynomials?
Resolving the recursion of Dickson polynomials involves using the recursive definition to compute values for specific \( n \). One approach is to start from the base cases \( D_0(x, y) \) and \( D_1(x, y) \), and iteratively apply the recurrence relation to compute higher-order polynomials. This can be done manually for small values of \( n \) or implemented in programming languages for larger computations to generate the polynomial values efficiently.
What are the applications of Dickson polynomials?
Dickson polynomials have several applications in mathematics and computer science. They are used in coding theory for constructing error-correcting codes, in cryptography for generating pseudorandom numbers, and in algebraic geometry. Additionally, they can be used to study the properties of finite fields and have connections to elliptic curves.
What are the properties of Dickson polynomials?
Dickson polynomials possess several interesting properties, including symmetry, periodicity, and the ability to generate a variety of algebraic forms. For instance, they exhibit symmetry in their arguments, meaning \( D_n(x, y) = D_n(y, x) \). They also have a degree of \( n \) in \( x \) and are linear in \( y \). Furthermore, they satisfy certain recurrence relations and can be evaluated at roots of unity, leading to connections with cyclotomic fields.
Can Dickson polynomials be generalized?
Yes, Dickson polynomials can be generalized to include various forms, such as generalized Dickson polynomials of the first and second kinds. These generalizations can involve different parameters or modifications to the recurrence relations, allowing for a broader class of polynomials that retain some of the properties of the original Dickson polynomials. Such generalizations are useful in exploring more complex algebraic structures and their applications.
