Resonance box with tuning fork, standing wave
In summary, the conversation discusses a resonance box with one closed end and one open end that reinforces the sound of a tuning fork with a frequency of 440 Hz. It also mentions the sound velocity of 340 m/s. The conversation then moves on to discussing the basis of the phenomenon, the shortest possible length of the resonance box, and the possibility of adding multiple tuning forks to the box.
late347
301
There is a resonance box with one end cloesd and the other end open. The box reinforces the sound of the tuning fork. That sound has frequency of 440 Hz
sound velocity is 340 m/s
a.) What is the basis of the phenomenon in question?
b.) define the shortest possible length of the resonance box
v= λ * f
I winced a little bit when I saw that a.) portion appear in my exam. I decide to skip this question on the basis of not being sure what kind of explanation was "enough"
We had an elective type of exam, choose 5 out of 6 problems. This one I skipped. I feel that I did have a rudimentary understanding of the situation and the basis of the phenomenon, but I was unsure if my understanding was
1) without error
2) good enough of an explanation
But the second question about the length is easier to answer in a more straightforward and mathematical manner. So, I will probably go with reverse order, first B and then A.
b.)
Find the wavelength first
## \lambda = \frac {v} {f} ##
## \lambda = 0.7727m ##
We know that between a node and another node there is ##\frac {\lambda} {2}##
In the resonance box, one wall of the box is closed with a node point, and the other side is open with an antinode.
## \frac {\lambda} {4} = l ##
## l = \frac {0.7727m} {4} = 0.2m ##
a.) explain the basis of the phenomenon
sound is a longitudinal wave, which requires a medium to travel in. The basis of the phenomenon appears to be such that a standing wave is created in the resonance box. And the node point will be the closed-off wall of the box, and the antinode is the open end.
I had a hazy recollection that the antinode is actually defined by the currently prevalent meteorological conditions, since the medium in this case appears to be air.
Standing waves themselves seem to be caused by a superposition of two waves which traveled in opposite directions. If the two waves have same amplitude, wavelength and frequency then it would seem that the standing wave is created.
Precisely how this happens in a resonance box, is a little bit unclear to me. It would seem that the tuning fork is the culprit for creating a sound wave, which is reinforced by the resonance box.
I'd have given you full marks :smile:
Everything sounds clear to me in your explanation. Do you understand why they asked for the shortest possible distance? There are other distances which would also resonate at the frequency (meaning there will be an antinode at the open end, and node at the closed end). How do these distances compare to the shortest distance?
The resonance length is fractionally longer than the physical length of the tube.
An 'end correction' must be added to the physical length of the tube, this can be determined experimentally.
Hey all! I am experimenting for a sound art project with tuning forks and resonance boxes. I have a complementary question to this thread:
If I have a resonance box specific for 1/4 λ of a given frequency of a tuning fork, can I add several tuning forks (all the same size and freq)?
Related to Resonance box with tuning fork, standing wave
What is a resonance box?
A resonance box is a hollow box with one open side and one closed side, designed to amplify sound waves.
What is a tuning fork?
A tuning fork is a small, metal instrument with two prongs that produces a specific musical pitch when struck. It is often used to tune musical instruments or as a standard for tuning.
How does a resonance box with a tuning fork work?
When a tuning fork is struck and placed inside a resonance box, the sound waves produced by the fork are amplified and create a standing wave inside the box. This standing wave resonates at the same frequency as the tuning fork, producing a louder and more sustained sound.
What is a standing wave?
A standing wave is a type of sound wave that remains in a fixed position and does not travel. It is formed when two waves with the same wavelength and amplitude travel in opposite directions and interfere with each other, creating points of constructive and destructive interference.
How is a resonance box with a tuning fork used?
A resonance box with a tuning fork is often used in physics experiments to demonstrate the concept of resonance and standing waves. It can also be used in musical performances to amplify the sound of a tuning fork or to create unique sounds by adjusting the size and shape of the resonance box.
  • Classical Physics
