Resonance frequency of confocal resonator
In summary, a symmetrical confocal resonator with a length of 30 cm and a refractive index of 1 will have a displacement frequency of 0 and a frequency spacing of 1.5*10^10 Hz. The resonance frequencies that fall within the band 5*10^14±2*10^9 Hz can be found by plugging in different values for n in the formula \nu_n = n\nuF.
semc
368
A symmetrical confocal resonator has a length d=30cm, and the medium has refractive index n=1. Determine the frequency spacing [itex]\nu[/itex]F and the displacement frequency ([itex]\Delta\varsigma[/itex]/[itex]\pi[/itex])[itex]\nu[/itex]F. Determine all the resonance frequencies that lie within the band 5*1014[itex]\pm[/itex]2*109Hz. [itex]\Delta\varsigma[/itex]= [itex]\varsigma[/itex](z1)-[itex]\varsigma[/itex](z2) where z1 and z2 are the position of the mirrors
[itex]\nu[/itex]F=c/2d
I can only find the resonance frequency. How can I get the phase shift [itex]\Delta\varsigma[/itex] from the length of the resonator?
To determine the phase shift \Delta\varsigma, you will need to use the formula \Delta\varsigma = 2\pi \Delta n L/\lambda, where \Delta n is the change in refractive index between the two mirrors, L is the length of the resonator, and \lambda is the wavelength of the light. Since the resonator is symmetrical, \Delta n will be zero and therefore \Delta\varsigma will also be zero. This means that the displacement frequency will also be zero, since it is given by (\Delta\varsigma/\pi)\nuF.
To determine the frequency spacing \nuF, you can use the formula \nuF = c/2d, where c is the speed of light and d is the length of the resonator. Plugging in the given values, we get \nuF = 1.5*10^10 Hz.
To determine the resonance frequencies within the given band, you can use the formula \nu_n = n\nuF, where n is the mode number. Since the given band is 5*10^14±2*10^9 Hz, we can plug in different values for n to find the resonance frequencies that fall within this range. For example, if we plug in n=335, we get a resonance frequency of 5.025*10^14 Hz, which falls within the given band.
FAQ: Resonance frequency of confocal resonator
1. What is the resonance frequency of a confocal resonator?
The resonance frequency of a confocal resonator refers to the frequency at which the resonator is able to amplify or sustain an electromagnetic wave. It is determined by the dimensions and materials of the resonator.
2. How is the resonance frequency of a confocal resonator calculated?
The resonance frequency of a confocal resonator can be calculated using the formula:
f = c/2L,
where c is the speed of light and L is the length of the resonator.
3. What factors can affect the resonance frequency of a confocal resonator?
The resonance frequency of a confocal resonator can be affected by factors such as the dimensions and shape of the resonator, the material it is made of, and the temperature.
4. How does the resonance frequency of a confocal resonator impact its performance?
The resonance frequency of a confocal resonator is crucial for its performance as it determines the wavelengths of light that can be amplified or sustained by the resonator. If the frequency is not properly matched, the resonator will not function effectively.
5. Can the resonance frequency of a confocal resonator be tuned?
Yes, the resonance frequency of a confocal resonator can be tuned by altering its dimensions or by adjusting the material properties. This allows for a wider range of wavelengths to be amplified or sustained by the resonator.
