Resonance gets sharper just by increasing the resonance freq, why?
In summary, the Q factor of an oscillating system is a measure of how sharp the resonance curve is, defined as the resonant frequency divided by the resonance width. In the case of a damped, driven harmonic oscillator, the cutoff frequencies are determined by the damping coefficient, which is proportional to the rate of change of x and thus, the frequency. Therefore, a higher resonant frequency leads to a sharper resonance curve, as the damping coefficient remains the same. The damping coefficient is a proportionality factor between the friction force and the velocity, and is responsible for the viscous friction force in the oscillator.
Aaron121
The ##Q## factor of an oscillating system is defined as ##\omega_{r}/\Delta \omega##, where ##\omega_{r}## is the resonant frequency, and ##\Delta \omega## the resonance width. As I understand, ##Q## measures how sharp the resonance curve is.
Why is it that the resonance curve gets sharper (higher ##Q##) just by virtue of having a higher resonant frequency, while keeping the same width ##\Delta \omega## ?
Who says ##\Delta \omega## does not change ?
@BvU For example, for a damped, driven harmonic oscillator with a natural frequency ##\omega_{0}##, the cutoff frequencies are at ##\sqrt{\omega_{0}^2+\frac{\gamma ^2}{4}}\pm \frac{\gamma}{2}##, where ##\gamma## is the damping coefficient. The equation of motion of the oscillator is given by ##\ddot{x}(t)+\gamma \dot{x}(t)+\omega_{0}^2 x(t)=F(t)/m##, (see page ##10## of this document). ##\Delta \omega##, in this case, is simply ##\gamma##, which doesn't depend on the resonant frequency ##\omega _{r}=\omega _{0}##.
You need to look closely at the damping coefficient and see how it is actually defined. I think you will find it refers to number of oscillations to reach 1/e or whatever. The scaling is implicit.
##\gamma## is the proportionality factor between the friction force ##\textbf{f}_{r}## and the velocity ##\dot{\textbf{x}}(t)##, i.e., ##\textbf{f}_{r}=-\gamma \dot{\textbf{x}}(t)##. The friction force is a viscous one.
That has the rate of change of x in it - aka proportional to FREQUENCY boom boom.
Related to Resonance gets sharper just by increasing the resonance freq, why?
1. Why does resonance get sharper when increasing the resonance frequency?
Resonance is a phenomenon that occurs when an object vibrates at its natural frequency. When the resonance frequency is increased, the object is forced to vibrate at a higher frequency, resulting in a sharper resonance. This is because at higher frequencies, the object has less time to complete a full cycle of vibration, making the vibrations more concentrated and intense.
2. What is the relationship between resonance frequency and sharpness of resonance?
The resonance frequency and sharpness of resonance are directly proportional. This means that as the resonance frequency increases, the sharpness of resonance also increases. This is because a higher resonance frequency results in a narrower bandwidth, meaning that the object is vibrating at a more specific frequency, resulting in a sharper resonance.
3. How does increasing the resonance frequency affect the amplitude of resonance?
Increasing the resonance frequency does not directly affect the amplitude of resonance. However, it can indirectly affect the amplitude by changing the damping factor of the object. A higher resonance frequency may result in a higher damping factor, which can decrease the amplitude of resonance.
4. Can the sharpness of resonance be increased without changing the resonance frequency?
No, the sharpness of resonance is directly related to the resonance frequency and cannot be increased without changing the resonance frequency. However, the sharpness of resonance can be affected by other factors such as damping, which can be adjusted without changing the resonance frequency.
5. What are some real-world applications of resonance and its sharpness?
Resonance and its sharpness have many real-world applications, such as in musical instruments, where the sharpness of resonance determines the quality of sound produced. It is also used in engineering, for example in the design of bridges and buildings to avoid structural resonance. In the medical field, resonance imaging (MRI) uses the sharpness of resonance to produce detailed images of the body's tissues and organs.
  • Classical Physics
  • Electromagnetism
