Resonance of water in a sphere
In summary, the link discusses the calculated and measured speeds of sound waves in water, as well as the concept of resonance in a spherical container filled with water. It is suggested that scaling the internal diameter of the container to the desired frequency should result in resonance, but it is important to also match the frequency of the point source to the desired frequency for successful resonance.
PH7SICS
23
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/souspe2.html
According to the above link the calculated speed of a wave in water is 1483m/s, whilst the measured speed of a wave in water was 1482m/s @ 20C
Imagine therefore we have a huge sphere with an internal diameter of 1482 meters and it is filled with water. At the centre of this sphere there is a point source of acoustic waves which occupies zero dimensions (its theoretical!). This point source emits an acoustic pulse the wave of which reaches the wall of the sphere in half a second and rebounds to reach the centre of the sphere in exactly one second.
If the point source was to be driven at one cycle per second or one Hertz resonance should therefore occur.
If my target resonant frequency was 42.8khz then it should be a matter of scaling i.e. 1482 / 42800 = 0.034626 meters or 34.62mm internal diameter.
obviously not sure about this so that is why I posted this here
.Yes, this calculation should be correct. The speed of sound in water is governed by the medium through which the wave travels, and so scaling the internal diameter of the sphere to the desired frequency will produce the correct result. Keep in mind that the frequency of the wave produced by the point source must also match the desired frequency of the resonant frequency, or else the resonance may not occur.
Related to Resonance of water in a sphere
1. What is resonance of water in a sphere?
Resonance of water in a sphere refers to the phenomenon where the water inside a spherical container vibrates at a specific frequency when it is exposed to external vibrations or sound waves.
2. How does resonance occur in a water sphere?
Resonance occurs in a water sphere when the natural frequency of the water inside the sphere matches the frequency of the external vibrations or sound waves, causing the water to vibrate and produce a distinct sound.
3. What factors affect the resonance of water in a sphere?
The resonance of water in a sphere can be affected by the size and shape of the sphere, the depth of the water, and the material and thickness of the sphere's walls. Additionally, the density and temperature of the water can also play a role in the resonance frequency.
4. Can resonance of water in a sphere be harmful?
No, resonance of water in a sphere is not considered harmful. It is simply a natural phenomenon that occurs when the conditions are right for resonance to occur. However, if the vibrations or sound waves are too strong, it can cause the water to splash out of the sphere.
5. How is resonance of water in a sphere used in science?
Resonance of water in a sphere is used in various scientific experiments and studies, such as studying the properties of sound waves and vibrations, determining the natural frequency of different materials, and even in musical instruments like the Tibetan singing bowl.
  • Mechanical Engineering
11K
9K
