Resonance relationship with glass shatter
In summary, the glass will only break when the sound waves are at the resonant frequency, and the amplitude of the sound waves is high enough to cause the glass to vibrate and shatter.
TT0
211
Just to check my understanding:
-The glass will only break when the sound is at the resonant frequency of the glass.
-This creates standing waves in the glass.
-The glass will only shatter if the sound is at a high enough volume (amplitude)
-Otherwise, at a lower volume at resonant frequency, no matter the duration, the glass will vibrate but not shatter
(resonance will cause the secondary object to vibrate at a certain energy but the object won't have increasing energy over time right?)
Could you please confirm my understanding?
Thanks a lot!
Correct. The reason why volume matters is that there is some dissipation.
A nice video on the subject:
Likes TT0
I see, that is a very nice video, thanks! So the vibrating glass is a form of standing waves right?
Also, since it took some time for the glass to break is it because despite the vibrations being of the same energy, each vibration weakens the structure of the glass and after enough weakening the glass shatters and not that a greater vibration occurs successively in the glass? (I am thinking about the swing analogy where each push will cause the swing to rise higher than previously, but I don't think it is the case for resonance, would you please confirm this.)
Thanks again
I would argue with "_only_ breaks at resonance". It might also break if subject to a very loud sound not at resonance.
The important thing to understand is that the maximum amount of power is transferred from the source to the load at resonance. The power transferred at other frequencies could still be enough to break it.
Likes TT0, davenn and Nidum
Thanks a lot!
Your statements seem to be correct. The glass could also shatter away from resonance if the amplitude was much greater.
This is my description in more detail:-
When the sound commences, the first wave will exert sound pressure against the glass, which will deflect slightly. Some of the energy will be dissipated as heat in bending the glass, but the majority will be stored in resonance as kinetic energy and elastic potential energy. The resonance mainly involves the bending of the glass rather than the volume of air in the glass. Each wave will cause the resonance to build up in amplitude as more energy is stored and also dissipated. The growth process is relatively slow, depending on the ratio of energy stored/energy dissipated per cycle. This is also called the Q of the resonator and may be in the order of 1000. The glass will also re-radiate sound, and when the energy dissipated equals half the incident energy, no more growth will occur.
The amplitude of the glass resonance is in quadrature to the incoming sound wave, and is proportional to Q. So it can be very large, larger than the sound wave displacement, as it is in quadrature to it. If this amplitude stresses the glass beyond its ultimate strength then the glass will break. If the sound ceases, the stored energy will gradually dissipate as heat and sound radiation.
Likes TT0
Related to Resonance relationship with glass shatter
1. How does resonance affect the shattering of glass?
Resonance is the phenomenon in which an object vibrates at its natural frequency when exposed to external vibrations of the same frequency. In the case of glass, the vibrations caused by resonance can amplify and weaken the structural integrity of the glass, leading to its shattering.
2. What type of glass is most susceptible to resonance-induced shattering?
Brittle and thin glass, such as wine glasses or light bulbs, are more likely to shatter due to resonance as they have a lower threshold for withstanding external vibrations. Thicker and tougher glass, like car windshields, are less likely to be affected by resonance.
3. Can resonance still cause glass to shatter if it is not at its natural frequency?
Yes, resonance can still cause glass to shatter even if it is not at its natural frequency. As long as the external vibrations are close enough in frequency to the natural frequency of the glass, resonance can occur and lead to shattering.
4. Can the shape of a glass object affect its susceptibility to resonance-induced shattering?
Yes, the shape of a glass object can play a role in its susceptibility to resonance-induced shattering. Objects with more complex shapes, such as a wine glass with a stem, can have multiple natural frequencies, making them more susceptible to resonance compared to simpler shapes like a solid glass sphere.
5. How can we prevent glass from shattering due to resonance?
To prevent glass from shattering due to resonance, the external vibrations need to be either reduced or avoided altogether. This can be achieved by using shock-absorbing materials, keeping the glass away from sources of vibrations, or designing the glass object to have a higher natural frequency than the expected external vibrations.
  • Classical Physics
  • Classical Physics
  • Electromagnetism
  • Classical Physics
  • Classical Physics
  • Classical Physics
