When Will the Next Resonance Occur in the Tuning Fork Experiment?
In summary, when the pipe is raised from the water, an increase in loudness is heard at intervals of one-quarter of the wavelength of the sound produced by the tuning fork. Therefore, the water level will be 81.6 cm from the top of the pipe when the next increase in loudness is heard.
Clean
[SOLVED] Resonance - Tuning fork volume
A narrow plastic pipe is almost completely submerged in a graduated cylinder full of water, and a tuning fork is held over its open end. The pipe is slowly raised from the water/ An increase in loudness of the sound is heard when the pipe has been raised 17 cm and again when it has been raised 51 cm.
If the pipe continues to be raised, how far from the top of the pipe will the water level be when the next increase is loudness is heard?
L = 5(wavelength)/4
L = 5(wavelength)/4
L = 5(68 cm)/4
L = 85 cm
Thanks!
I would like to provide a more detailed explanation of the phenomenon observed in this experiment. The increase in loudness of the sound when the pipe is raised from the water is due to a phenomenon called resonance. Resonance occurs when a vibrating object, such as the tuning fork, causes another object, in this case the air column in the pipe, to vibrate at its natural frequency.
In this experiment, the length of the air column changes as the pipe is raised from the water. The first increase in loudness occurs when the length of the air column is equal to one-quarter of the wavelength of the sound produced by the tuning fork. This can be calculated using the formula L = 5(wavelength)/4, where L is the length of the air column and wavelength is the distance between two consecutive compressions or rarefactions in the sound wave.
Using the given information, we can solve for the wavelength of the sound produced by the tuning fork:
L = 5(wavelength)/4
17 cm = 5(wavelength)/4
wavelength = (17 cm * 4)/5 = 13.6 cm
Therefore, the wavelength of the sound produced by the tuning fork is 13.6 cm. This means that when the pipe is raised 17 cm from the water, the length of the air column is equal to one-quarter of the wavelength and resonance occurs, resulting in an increase in loudness.
The second increase in loudness occurs when the length of the air column is equal to three-quarters of the wavelength. This can be calculated by adding one wavelength to the length of the air column calculated in the first step:
L = 5(wavelength)/4
51 cm = 5(wavelength)/4
wavelength = (51 cm * 4)/5 = 40.8 cm
Therefore, when the pipe is raised 51 cm from the water, the length of the air column is equal to three-quarters of the wavelength and resonance occurs again.
To find the next point at which an increase in loudness will occur, we need to add one more wavelength to the length of the air column calculated in the second step:
L = 5(wavelength)/4
wavelength = (40.8 cm + 40.8 cm) = 81.6 cm
This means that when the pipe is raised 81.6 cm from the water, the length of the air column will be
Related to When Will the Next Resonance Occur in the Tuning Fork Experiment?
What is resonance?
Resonance is the tendency of a system to oscillate at a certain frequency when it is exposed to an external source of energy at that same frequency.
How does resonance apply to tuning forks?
Tuning forks are designed to vibrate at a specific frequency, and when struck, they produce a pure and consistent sound due to resonance. The frequency of the sound produced is the same as the natural frequency of the tuning fork.
Why does the volume of a tuning fork decrease over time?
The volume of a tuning fork decreases over time due to the dissipation of energy. When the tuning fork is struck, it vibrates and produces sound waves, but these waves eventually lose energy and dissipate, resulting in a decrease in volume.
How can the volume of a tuning fork be increased?
The volume of a tuning fork can be increased by striking it with a greater force. This will cause the tuning fork to vibrate with a larger amplitude, resulting in a louder sound.
What factors affect the volume of a tuning fork?
The volume of a tuning fork is affected by its material, size, shape, and the force used to strike it. These factors determine the natural frequency of the tuning fork and therefore, the volume of sound it produces when struck.
  • Classical Physics
