Resonant frequencies in a tube with adjustable length
The discussion revolves around determining the resonant frequencies of a 1m long tube using a 1024 Hz tuning fork, with the speed of sound set at 344 m/s. It concludes that there are six resonant lengths for the air column corresponding to this frequency, but the question is deemed misleading as it implies multiple resonant frequencies from a single tuning fork. Participants clarify that the resonance conditions in a half-closed pipe yield odd multiples of quarter wavelengths, leading to the conclusion that while six lengths resonate at 1024 Hz, the actual frequencies can extend infinitely when considering harmonics. The conversation highlights the importance of correctly interpreting the question to distinguish between the fundamental frequencies of the pipe and the harmonics of the tuning fork. Ultimately, the discussion emphasizes the complexity of resonance in acoustics and the need for precise language in scientific queries.
Von Neumann
Problem:
Determine the quantity of resonant frequencies that a 1024 Hz tuning fork will have in a 1m long tube with an adjustable water level. Find the length of the air column for each frequency. Assume the speed of sound is 344m/s.
Solution:
The resonant frequencies are odd integer multiples of the fundamental so,
f=(2n-1)f'
(where f' is the 1st resonant, n the number of nodes, and f is the nth resonant frequency)
f=(2n-1)v/\lambda
=(2n-1)v/(4l)
= [(n-1/2)v]/(2l)
Solving for l,
l=[(n-1/2)v]/(2f)
Substituting values of n into the equation until l > 1m,
n=1
l=8.4cm
n=2
l=25.2cm
n=3
l=42.0cm
n=4
l=58.8cm
n=5
l=75.6cm
n=6
l=92.4cm
Plugging in n=7 yields a length of 1.08 m, so the wave is no longer within the tube. Therefore there are 6 resonant frequencies.
Is this correct?
I think unfortunately this question as stated is meaningless. Tuning forks only make one frequency so why is the question asking about the quantity of resonant frequencies? This has misdirected your thinking.
If the question actually is asking " at what lengths of tube up to 1m does resonance occur for this single frequency?" then I agree with your answers but not your reasoning.
The condition for resonance in a half closed pipe is:
L=\frac{λ}{4}(2n-1)
Where λ has one value given by 344/1024.
Your final equation is equivalent to this if you make f=1024 only ie only one frequency, which is what you must have done.
If we can have any frequency as long as it is an odd multiple of 1024Hz then there are infinite answers since we have an infinite number of possible λ values.
ie
if f=1024Hz we get 6 lengths
if f=3*1024 we get 18 lengths
if f=5*1024 we get 30 lengths
if f=(2n-1)*1024 we get 6*(2n-1) lengths
Which clearly leads to an infinite sum.
f=(2n-1)v/\lambda
What exactly is λ here? I think you want the wavelength that goes with f, not f'. So the equation becomes: fn=v/λn=(2n-1)f'. The harmonics have higher frequencies, so shorter wavelengths.
This leads to the infinite sequence apelling demonstrates.
As already stated, that is precisely the equation I used; namely f=(2n-1)f'. λ is the wavelength associated with the specific tuning fork used in the experiment. Essentially, a tuning fork is an instrument that resonates at a certain constant pitch when struck. In this case the frequency is 1024 Hz. Since f = v/λ => λ = v/f = 344/1024.
As apelling stated, since the condition for resonance in an open-end pipe only supports odd multiples of quarter wavelengths, we get l=λ/4(2n-1). Since the maximum length l of the adjustable air column is 1m, there is only a finite number permitted within the tube for the frequency at hand. Hope that clears it up.
Thanks guys.
What you have calculated is the number of lengths of air column that will resonate to a given frequency, 1024Hz. The question clearly asks for a number of frequencies. This led both apelling and me to conclude you needed to consider harmonics of 1024Hz, and we both arrived at the answer that there would be an infinite number of them.
But I now see that the question is quite misleading, though you seem to have read it as intended. It's not the "resonant frequencies that a 1024 Hz tuning fork will have", it's the fundamental frequencies of the pipe that will have 1024Hz as a harmonic.
