Resonant frequencies of a membrane, dependance on Young's modulus?
In summary, the natural frequencies of a circular membrane are determined by the m-th positive root of the Bessel Function of the first kind of order n, where ξmn represents the radius of the membrane and c is the velocity of wave propagation. The tension of the membrane is a key factor in determining the natural frequencies, but it can be difficult to determine in real-world scenarios. When running FEM modal analysis, the program is able to calculate the natural frequencies and mode shapes based on the geometry and material properties, but the tension must be specified. It is possible to express the natural frequencies in terms of the material properties independently of the prestress. Young's modulus does have an impact on the natural frequencies, even though it is not explicitly
kravky
Hello,
natural frequencies of (circular) membrane are expressed in every textbook as:
where
is the m-th positive root of the Bessel Function of the first kind of order n. For m=1, n=0: ξmn = 2,405.
represents the radius of membrane, and
is the velocity of wave propagation (transverse).
in every book there is an equation for velocity as follows:
where
is the density of membrane,
represents the thickness of the membrane and
is tension: force per unit length - dimension is therefore Newtons per meter.
I want to focus on the Tension. From the equations we can see, that the natural freq. depends on tension which makes sense. However how can i know the tension of the membrane? e.g tension of the ear drum, or tension of the membrane in microphone..
When we run FEM modal analysis in some program, we need only specify the geometry (radius) and material properties, such as Youngs modulus E, poissonous ratio and the density, and the program succesfully finds the natural modes of a membrane (e.g. clamped membrane). So my question is: How the program knows the tension? How can the software calculate the frequencies and mode shapes?
Is there a possibility to express natural freq. of membrane in terms of Youngs modulus, poissonous ratio, density, thickness, radius INDEPENDENTLY ON THE PRESTRESS (PRETENSION) ?
How Youngs modulus depends on the pretension? is there any relationship behind it?
Because in FEM we can see clear eveidence, that natural freq. does depend on the Youngs modulus E. However the equation in books does not contain Youngs modulus. It means that something is worng ?
Imagine we set in FEM simulation some pretension and we choose a value for Youngs modolus and so on... If we change the Youngs modulus the natural freq. will change however the equation says it will not change :-D
I don't understand physics behind this finding of natural freq. Maybe i don't understand what this tension means.
If You could help me, i would appreciate it greatly.
From your equation, what are the units of T?
The units of T are [N/m]. It means it is a force per unit length (Newtons/metres). unit of h is meter [m] and the units of rho are [kg/m^3].
This is correct. So the physical interpretation of T is tensile stress times thickness, or force per unit length along any segment of cut within the plane of the membrane. Along the rim of the membrane, T is the tensile force per unit length around the circumference.
Related to Resonant frequencies of a membrane, dependance on Young's modulus?
1. What is the definition of resonant frequency?
Resonant frequency refers to the natural frequency at which an object vibrates with the greatest amplitude when it is excited by an external force.
2. How is the resonant frequency of a membrane determined?
The resonant frequency of a membrane is determined by its physical properties, such as its size, shape, and material properties. It can be calculated using the equation: f = (1/2π) * √(T/ρ), where f is the resonant frequency, T is the tension in the membrane, and ρ is the density of the membrane material.
3. What is Young's modulus and how does it affect the resonant frequency of a membrane?
Young's modulus is a measure of the stiffness or elasticity of a material. It describes how much a material will deform under a given amount of stress. The higher the Young's modulus, the stiffer the material and the higher the resonant frequency of a membrane made from that material will be.
4. Can the resonant frequency of a membrane be changed?
Yes, the resonant frequency of a membrane can be changed by altering its physical properties, such as its tension, size, shape, or material. For example, increasing the tension in a membrane will increase its resonant frequency, while decreasing the tension will decrease the resonant frequency.
5. What are some real-world applications of understanding the resonant frequencies of a membrane?
Understanding the resonant frequencies of a membrane is important in various fields, such as acoustics, music, and engineering. It is used in designing musical instruments, such as drums and strings, to produce desired tones. It is also important in designing structures, such as bridges and buildings, to ensure they can withstand vibrations and avoid resonance disasters. Additionally, it is used in medical imaging techniques, such as ultrasound, to produce clear images by utilizing the resonant frequencies of body tissues.
  • Other Physics Topics
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • General Engineering
