Resonant frequency and circumference of spheres
In summary, the Schumann resonances are modes within a conducting sphere. The Schumann resonances begin when ka = 1, where ka is the circumference of the sphere measured in wavelengths. The Schumann resonance equation is c/(2*pi*earth_radius) * sqrt(n*(n+1)) which comes out to be 7.49 hz. However, the real Schumann frequency is 7.8 hz.
nuby
336
Does the electromagnetic or acoustic resonant frequency of a hallow spherical object ever equal the circumference of that object? If not what are the formulas to calculate this? Thanks in advance.
A circumference is a distance. A resonant frequency is a frequency. Talking about a distance being equal to a frequency doesn't make sense; it's like asking if your age equals your name.
True... I think I asked the wrong question..
Anyway, do you know the equation to calculate the resonant frequency of a hollow sphere, and string?
Thanks.
I meant to ask if wavelength or 1/wavelength is ever equal to the circumference of an spherical object.
In which context?
I suggest you google "whispering gallery resonator",although they are no spherical but cylindrical.
Does this look right for sphere resonance?
f = v / (2*pi*r)
The previous post described EM resonances internal to a conducting sphere. The complementary exterior problem results in scattering of EM waves off of a conducting sphere. This is known as Mie scattering and the solutions and equations are not simple (the scattered waves are combinations of reflections from the front with resonant "creeping waves" that travel over the spherical surface). However resonances begin when [tex]ka = 1[/tex], where [tex]ka [/tex] is the circumference of the sphere measured in wavelengths.
You can find the mathematical details in Jackson, Classical Electrodynamics, 2nd ed., section 9.13. The plot of how the scattering amplitude changes with circumference is found in every discussion of radar scattering cross section. See, e.g., Fig. 7 in
http://www.tscm.com/rcs.pdf"
A little off topic, but ...
Does the Schumann resonance have more to do with the ionosphere or the molten iron within the earth? According to Wiki, it has to do with the ionosphere and Earth's surface. But why is this:
Schumann resonance equation: c/(2*pi*earth_radius) * sqrt(n*(n+1))
Which comes out to be 7.49 hz ..
switch: earth_radius to earth_radius + ionosphere_elevation .. you get 7.15 hzBut the real Schumann frequency is 7.8 hz ...
Since the upper mantel depth is right around 250,000 meters
Wouldn't c/(2*pi*(earth_radius - upper_mantel_depth)) make sense?
So you get the real Schumann frequency of 7.8hz?
The Earth's surface looks like a good conductor when viewed on a large scale. Ground is used as the return conductor for AC power transmission, for instance. The wavelength at 7 Hz = 37000 km, so underground water tables contribute to the apparent conductivity, and any local surface features are irrelevant. The Earth is largely covered with conductive oceans, furthermore. I doubt that you need to consider the molten core.
EDIT: I just noticed you are talking about a depth of just 250 km. I suppose there might be some penetration that deep, although I still think the crust and water tables are quite conductive.
Had a chance to look into Schumann resonances a little. Jackson points out that, of the two boundaries, it is the ionosphere that departs most from a perfect conductor and as a result the resonances vary with daily changes in the ionosphere.
Given these factors, your agreement (7.5 vs. 7.8 Hz, or within 4%) is excellent.
FAQ: Resonant frequency and circumference of spheres
What is resonant frequency?
Resonant frequency is the natural frequency at which an object vibrates or oscillates when it is disturbed.
How is resonant frequency calculated?
Resonant frequency is calculated using the formula f = 1/2π√(k/m), where f is the resonant frequency, k is the spring constant, and m is the mass of the object.
What is the significance of resonant frequency in spheres?
In spheres, resonant frequency is important because it determines the natural vibration modes of the object and can affect its stability and structural integrity.
How does the circumference of a sphere affect its resonant frequency?
The circumference of a sphere does not directly affect its resonant frequency. However, the size and shape of the sphere can impact the distribution of mass and stiffness, which can affect the resonant frequency.
Can resonant frequency be changed in spheres?
Yes, the resonant frequency of a sphere can be changed by altering its mass, stiffness, or shape. For example, adding weights or changing the material of the sphere can change its resonant frequency.
