Restricting Domain and Range in broken conics
In summary, restricting the domain and range in broken conics is done to focus on a specific part of the graph and simplify it for analysis. This is achieved by using inequalities or interval notation to specify the range of values included in the graph. This restriction changes the shape and behavior of the graph and limits the possible solutions of a problem. Common examples include restricting to positive or negative values, even or odd numbers, or a specific interval. It is important to understand this concept for accurate graph interpretation and solving real-world problems, as well as for advanced math courses.
xxfamousxx91
How do you know whether you restrict the domain or range with a horizontal ellipse ?
x^2/49 +y^2/10=1
Since y2 is never negative, x will be largest when y= 0. And when y= 0, [itex]x^2/49= 1[/itex], [itex]x^2= 49[/itex], [itex]x= \pm 7[/itex]. [itex]-7\le x\le 7[/itex]. Similarly, if x= 0 [itex]y^2/10= 1[/itex] so [itex]y= \pm\sqrt{10}[/itex]. If x is not zero, [itex]y^2[/itex] is smaller than 10 so [itex]-\sqrt{10}\le y\le\sqrt{10}[/itex].
Restricting the domain and range in broken conics, such as a horizontal ellipse, is important in order to accurately represent the data and avoid any misleading information. In the equation x^2/49 +y^2/10=1, the domain and range can be restricted by setting limits on the values of x and y. For a horizontal ellipse, the domain can be restricted by setting a limit on the values of x, since the major axis of the ellipse is parallel to the x-axis. This can be done by determining the x-intercepts of the ellipse and setting those as the limits for the domain. Similarly, the range can be restricted by setting limits on the values of y, since the minor axis of the ellipse is parallel to the y-axis. This can be done by determining the y-intercepts of the ellipse and setting those as the limits for the range. It is important to carefully consider the data and the purpose of the graph when determining the appropriate restrictions for the domain and range in broken conics.
Related to Restricting Domain and Range in broken conics
1. What is the purpose of restricting the domain and range in broken conics?
The purpose of restricting the domain and range in broken conics is to focus on a specific part of the graph and to exclude any values that are not relevant to the given problem or situation. This can help to simplify the graph and make it easier to analyze.
2. How do you restrict the domain and range in broken conics?
To restrict the domain and range in broken conics, you can use inequalities or interval notation to specify the range of values that are included in the graph. For example, if you want to restrict the domain to only positive values, you can use the inequality x > 0 or the interval (0, ∞).
3. What happens when you restrict the domain and range in broken conics?
When you restrict the domain and range in broken conics, it changes the shape and behavior of the graph. This is because the restricted values are no longer included in the graph, resulting in breaks or gaps in the shape. It also limits the possible solutions or outcomes of the problem.
4. What are some common examples of restricting domain and range in broken conics?
Some common examples of restricting domain and range in broken conics include limiting the domain to positive or negative values, restricting the range to only even or odd numbers, and narrowing the domain and range to a specific interval or range of values.
5. Why is it important to understand how to restrict domain and range in broken conics?
Understanding how to restrict domain and range in broken conics is important because it allows you to analyze and interpret graphs more accurately. It also helps in solving real-world problems by identifying relevant values and excluding irrelevant ones. Additionally, it is a fundamental concept in calculus and other advanced math courses.
