Restrictions on Variables for Simplified Expression
  • MHB
  • Thread starter mathdrama
  • Tags
    Variables
In summary, the original expression and the simplified expression are not the same, but with proper restrictions on the variables, they can be made equivalent.
mathdrama
I'm not really sure where to put this, it's from an MCR3U course(Advanced Functions):
Simplify and state the restrictions on the variables.
a) (3x)2/4xy * 16y/36x
I got as far as
= 12xy2/36x2y
= Xy2/3x2y
= 3x-1y
but I don't really know how to state the restrictions. Thanks in advance.
Mathematics news on Phys.org
I got as far as
= 12xy2/36x2y
= Xy2/3x2y
= 3x-1y
Please note that the original and the simplified expression are not the same! For instance, the simplified expression has no restrictions on the two variables $x$ and $y$ (it is defined for any two real numbers), however the original expression has some discontinuities (look at divisions by zero), and at precisely these points, it is not defined (and since the simplified expression is, they are not equivalent!). In order to make the statement "(3x)2/4xy * 16y/36x = 3x-1y" true, you have to impose restrictions on the variables $x$ and $y$ such that:
- if one expression is defined at $(x, y)$, then the other is also defined at $(x, y)$ and they are equal at that point
- if one expression is not defined at $(x, y)$, then the other is not defined either
In this case, the simplified expression is defined everywhere, but the original expression is not defined as specific points $(x, y)$ (can you find them?), so you need to define the simplified expression to exclude these points, and then the equality will be true. If you're wondering how to write them down, this would do:
... = 3x - 1y for (x, y) not equal to [...]
(usually you don't have to list every single pair (x, y), you can often simplify them into a smaller set of equivalent restrictions)
However I should note that you made a mistake in your simplification. But just to be sure, did you mean:
$$3x \frac{2}{4xy} \times \frac{16y}{36x}$$
Sorry, I'm not sure how to describe the expression on this forum. Does this link help? http://i57.tinypic.com/t8105t.png
"Please note that the original and the simplified expression are not the same! " When you say this, is this because there was a mistake in the simplification, or is that how it works?
[snip]
Ah, ok, with the $3x$ raised to a power it would make a difference. Haven't checked, but I'll assume the expression is right.
The simplification you gave in your opening post is technically "wrong", in the sense that the two are not equivalent, as I've said above. However they are "almost" the same, they only differ at a few points (due to you implicitly making assumptions on the possible values of $x$ and $y$ while manipulating the expression, e.g. division by zero) which is exactly why you need to put restrictions on the variables to make it correct. Once you add the restrictions, the original and simplified expression are the same, which is the point of the exercise :p
I got as far as
= 12xy2/36x2y
= Xy2/3x2y
= 3x-1y
Welcome to MHB, mathdrama!
Let's see...
\(\displaystyle \frac{(3x)^2}{4xy} \cdot \frac{16y}{36x} \)
\(\displaystyle =\frac{3^2x^2 \cdot 16y}{ 4xy \cdot 36x} \)
\(\displaystyle =\frac{9x^2 \cdot \cancel 4 \cdot 4y}{\cancel 4xy \cdot 36x} \)
\(\displaystyle =\frac{9x^2 \cdot 4y}{xy \cdot 36x} \)
\(\displaystyle =\frac{36x^2y}{36x^2y} \)
Hmm... that does not look the same as what you have...
Let's see...
Thank you. To make sure I understand this, the way to find the restrictions is to make the common denominator = 0, right?
In the simplified expression, I would have to make 36x^2y = 0, right?
The thing is, I don't know how to factor 36x^2y.
Is it (x + 6)(x + 6)y = 0
In general, you want to look at the original expression, at least before any factors are divided out or singularities removed to determine the restrictions.
The original form is:
\(\displaystyle \frac{(3x)^2}{4xy} \cdot \frac{16y}{36x}\)
we could first find the product:
\(\displaystyle \frac{144x^2y}{144x^2y}\)
Now, before you reduce, look at what can cause the denominator to be zero. When the denominator is a set of factors, then we can use the zero-factor property, which essentially states that when we equate the product of some factors to zero, then if anyone of those factors is zero, the product is zero, since zero times any finite value is zero.
We know 144 can never be zero, so we look at:
\(\displaystyle x^2=0\implies x=0\)
\(\displaystyle y=0\)
So, we cannot have those values for $x$ and $y$. Now we may simplify:
\(\displaystyle \frac{\bcancel{144x^2y}}{\bcancel{144x^2y}}=1\)
Hence, the original expression is equivalent to 1 where $x\ne0$ and $y\ne0$.
Yes.
As Mark already remarked, no, you have to check the original expression.
Each individual denominator that can be zero causes a restriction.
It is already factorized.
More specifically:
$$36x^2y = 36 \cdot x^2 \cdot y = 36 \cdot x \cdot x \cdot y$$
Oh, now I finally understand.
Thank you very much kind MHB folks.
FAQ: Restrictions on Variables for Simplified Expression
What are restrictions on variables?
Restrictions on variables refer to limitations or rules that must be followed when using different types of variables in a scientific study or experiment. These restrictions may include the type of variable that can be used, the range of values it can take, and how it is measured or manipulated.
Why are restrictions on variables important?
Restrictions on variables are important because they help ensure that the data collected in a scientific study is accurate and meaningful. By setting limitations on variables, researchers can control for potential confounding factors and make sure that their results are valid and reliable.
What are some common types of restrictions on variables?
Some common types of restrictions on variables include operational, conceptual, and statistical restrictions. Operational restrictions refer to how a variable is measured or manipulated, while conceptual restrictions define the boundaries and definitions of a particular variable. Statistical restrictions involve the use of specific statistical tests or techniques to analyze the data.
How do researchers determine restrictions on variables?
The determination of restrictions on variables is a crucial step in the design of a scientific study. Researchers must carefully consider the objectives of their study, the research question they are trying to answer, and the potential limitations or biases that may affect their results. They may also consult with other experts in the field and review relevant literature to inform their decisions.
Can restrictions on variables change during a study?
In some cases, restrictions on variables may change during a study. This could happen if new information or unexpected results arise, or if researchers need to adjust their methods or design. However, any changes to restrictions on variables should be carefully considered and clearly documented to maintain the integrity of the study and its results.
