Result of bleach+tartaric acid >>> ?
  • Thread starter Emmanuel_Euler
  • Tags
    Acid
In summary, the conversation discusses a reaction between NaClO and C4H6O6, with the potential result being oxidation of the OH groups to ketones followed by decarboxylation. The reaction is a double replacement reaction driven by the formation of weak acid Hypochlorous Acid. The possibility of further oxidation is also mentioned, with a source provided for further reading. The conversation ends with the speaker expressing gratitude for the help and stating that they have a question to ask at a later time due to being busy.
Emmanuel_Euler
142
Hello Everyone
Please can you tell me what is the result of this reaction??
NaClO+C4H6O6>>>
NOTE:This is not a homework,i did this simple reaction yesterday.
Chemistry news on Phys.org
Off the top of your head, what do think may happen? Did you observe any evidence for a reaction?
Likes Emmanuel_Euler
Could imagine some oxidation of the OH groups to ketone followed by decarboxylation.
This is a double replacement (metathesis) reaction with the driving force being a weak acid Hypochlorous Acid formed by hypochlorite ion (ClO-) extracting one of the Hydrogens from the Tartic Acid giving Sodium Hydrogen Tartrate. (Ka(HClO) = 3.5 x 10-8 @ 25oC)
NaClO(aq) + H2C4H4O6(aq) => NaHC4H4O6(aq) + HClO(aq)
That's definitely a first step, but I am with DrDu - some oxidation can happen.
Thank you so much for help.
I want to ask something but not now!
This days i am too busy.
FAQ: Result of bleach+tartaric acid >>> ?
What is the result of combining bleach and tartaric acid?
The result of combining bleach and tartaric acid is the formation of a chemical reaction that produces carbon dioxide gas, water, and a salt compound called sodium tartrate.
Is it safe to mix bleach and tartaric acid?
No, it is not safe to mix bleach and tartaric acid. The reaction between these two chemicals can release toxic gases and cause skin and eye irritation. It is important to handle these chemicals with caution and to avoid mixing them together.
Can bleach and tartaric acid be used for cleaning?
Yes, bleach and tartaric acid can be used for cleaning, but they should not be mixed together. Bleach is a strong disinfectant and can kill germs and bacteria, while tartaric acid can help remove stains and mineral deposits. It is recommended to use these chemicals separately for cleaning purposes.
How does tartaric acid affect the bleaching process?
Tartaric acid can act as a bleaching agent when combined with bleach. It can help increase the bleaching power of bleach and make it more effective in removing stains and whitening fabrics. However, it is important to use the correct amount of tartaric acid to avoid damaging the fabric.
What safety precautions should I take when using bleach and tartaric acid?
When using bleach and tartaric acid, it is important to wear protective gear such as gloves and eye protection. These chemicals should also be used in a well-ventilated area to avoid inhaling any toxic fumes. It is also important to carefully follow instructions and avoid mixing these chemicals together to prevent any accidents or harmful reactions.
