kelvin macks said:Homework Statement
my question is on part a , the ans is 4260N . but my answer is double of the ans given. why I'm wrong? the working is shown in the photo.
dean barry said:You've maybe put 0.12 m as the crank radius when it should be 0.06 m
r = crank radius = 0.06 metres
w = crank rotation rate = 376.99112 rad / sec
Find the tangential velocity (v) from :
v = w * r
v = 376.99112 * 0.06
v = 22.619 m/s (ANSWER b)
Find the centripetal acceleration (a) :
a = v ² / r
a = 8,527.338 (m/s)/s
The decelerating force (f) = m * a
f = 0.5 * 8,527.338 N
f = 4,263.67 N (ANSWER a)
The resultant force on the piston at the end of stroke is the net force acting on the piston at the end of its movement. This force is a combination of all the forces acting on the piston, including the pressure from the fluid, the weight of the piston, and any other external forces.
The resultant force can be calculated by summing all the forces acting on the piston, taking into account their direction and magnitude. This can be done using vector addition or by using the equation F = P x A, where F is the resultant force, P is the pressure, and A is the area of the piston.
The resultant force on the piston can be affected by various factors such as the pressure of the fluid, the area of the piston, the weight of the piston, and any external forces acting on it. Changes in these factors can alter the resultant force and affect the performance of the piston.
The resultant force on the piston determines the acceleration and velocity of the piston. A greater resultant force will result in a faster motion of the piston, while a smaller resultant force will result in a slower motion. The direction of the resultant force also determines the direction of the piston's motion.
To optimize the resultant force on the piston, engineers can adjust the design of the piston, such as its size and weight, and the pressure and properties of the fluid. By carefully considering these factors, the resultant force can be optimized to achieve the desired performance of the piston.
