Resultant torque of a solid object
In summary, the resultant torque of a solid object is the combined rotational forces acting on the object and can be calculated using the formula T = F x d. Factors such as the magnitude and direction of the applied force and the distribution of mass affect the resultant torque. Understanding resultant torque is important in designing and analyzing the stability and balance of structures and machines, as well as in fields like engineering, physics, and biomechanics.
Lone Wolf
A solid object rotates around an axis perpendicular to the plane of the figure and that goes through point A, due to the action of two forces applied in opposite sides of the object and with opposite directions; the resultant torque is proportional to the time squared. At the instant t = 0, Θ = 0 and ω = 0, and 5 seconds later, ω = 100 rad/s. The kinetic energy of the solid increases 1064 J between t = 3 and t = 2 s.
Find:
a) The moment of inertia of the solid relative to the axis of rotation.
b) The torque at the instant where the angular acceleration is 38.4 rad/s².
τ = Iα
K = 1/2 * I * ω²
244557
a) ΔK = 1064 = 1/2 * I * (ω²(3) - ω²(2))
I = 2*1064/(ω²(3) - ω²(2))
If I assume α = n*t²:
α = dω/dt --> ω = ∫ n* t² dt = n*t³/3 + ω0 = n*t³/3
ω(5) = 100 = n*5³/3 --> n = 2.4
α = 2.4 t² and ω = 2.4 * t³/3
ω(3) = 21.6 rad/s and ω(2) = 6.4 rad/s. Replacing the values:
I = 2*1064/(21.6²-6.4²) = 5.0 kg m²
b) Using the previous value:
τ = I α;
τ = 5.0 * 38.4 = 192 N m
Does that seem okay?
I didn't check your arithmetic, but your approach looks good to me.
Likes Lone Wolf
I have. All good.
Likes Lone Wolf and Doc Al
Related to Resultant torque of a solid object
What is the definition of resultant torque?
Resultant torque is the rotational equivalent of force and is the measure of the turning or twisting effect of a force applied to a solid object.
How is resultant torque calculated?
Resultant torque is calculated by multiplying the magnitude of the force by the perpendicular distance between the force and the axis of rotation.
What factors affect the resultant torque of a solid object?
The magnitude of the force, the distance from the axis of rotation, and the direction of the force all affect the resultant torque of a solid object.
What is the unit of measure for resultant torque?
The unit of measure for resultant torque is newton-meters (Nm) in the SI system and foot-pounds (ft-lb) in the imperial system.
Why is understanding resultant torque important?
Understanding resultant torque is important in engineering and physics as it allows us to predict the rotational motion of objects and design structures that can withstand external forces.
22K
