Results of steam bubbles in the reactor
In summary, a loss of pressure in a pressurized water reactor can lead to the formation of steam bubbles on the fuel rods, which increases the risk of fire.
David Carroll
181
When I was in the Navy, we were told of the immense importance of maintaining pressure inside the reactor (all the reactors in the Navy use a hydrogen moderator via water). My teacher discussed that one of the results of loss of pressure could be the formation of steam bubbles collecting on the fuel rods. The reason why this is dangerous is because the molecules on the surface of the rods had fewer H2O molecules to collide with and would therefore radiate heat via infrared waves. But I don't recall learning why it was that molecules should act this way. Quantum physics wasn't really stressed that much in the Navy's curriculum.
What is happening on the quantum level that makes molecules radiate infrared energy when that energy is not able to be transferred via molecular collision?
The concern about boiling in a pressurized water reactor (PWR) is primarily about departure from nucleate boiling (DNB). There is sometimes nucleate boiling in hotter or highly rated PWRs, depending on local peaking factors, coolant temperature and pressure. Boiling reduces moderation in that region of the core. Nucleate boiling improves heat transfer, but if there is too much steam, then the heat transfer is reduced. Following DNB, a layer of steam may form on the surface of the cladding surface. Steam has poor thermal conductivity compared to liquid water at the same temperature, and for a given heat flux, the surface temperature and fuel temperature will increase.
The comment about infrared is probably a reference to radiative heat transfer, which is rather weak compared to conduction and convective heat transfer. Hot objects (e.g., radiators used to heat rooms) will radiate in the infrared, and eventually in the visible.
The other aspect of boiling is corrosion of the underlying metal surface, which is a concern if the corrosion rate accelerates greatly, and the metal transforms to an oxide. Too much corrosion/oxidation may lead to a breach of the cladding and loss of fission products to the coolant.
Thank you, sir.
To add to what Astronuc posted, DNB is of safety concern because it is a runaway, positive-feedback reaction which can lead to fuel damage/melting. If the fuel temperature becomes too high, the coolant will start to boil. The boiling reduces the heat transfer capability of the coolant, thus leading to even higher fuel temperature, which leads to even more boiling, etc, until the fuel becomes "dry" (only steam). At this point the cladding will burn and/or fuel will will melt.
Could this also be caused by turbulence in the coolant flow? Doesn't fluid turbulence result in pressure differentials?
No, in fact turbulence is desirable and intentionally induced using vanes to keep the coolant mixed, which helps prevent DNB.
Think about cooking a pot of stew. If you don't stir it, you will form a steam bubble on the bottom which may burst and explode hot stew in your face. If you do stir it, the stew remains at a uniform temperature and doesn't explode.
Ahhh, I see.
Hi you David. Sorry to be late to the thread.
After dry out, convection heat transfer fails and the only local mechanism is radiation heat transfer, which you may recall is proportional to the fourth root of the absolute temperature difference - not any where as efficient as conduction or convection.
But before dry out there are a number of wet regimes characterized by less and less moisture available for Hx.
While fully wet, nucleate boiling increases the mass flux and heat flux at the channel surface. The 'bubbles' cause considerable turbulence (mass flux) and the energy (heat flux) of bubble formation is the heat/thermal energy of that differential volume. Nucleate boiling is a beneficial but transient state, with burn-out on the right hand of the curve. The operating envelope avoids nucleate boiling for the unpredictability of DNB departure for nucleate boiling.
Do you recall this curve. It's similar to what I used to teach (1980 - 1993) in this area of this subject.
https://upload.wikimedia.org/wikipedia/en/thumb/4/49/Boiling_Curve.jpg/450px-Boiling_Curve.jpg
My text for this subject came from Boiling crisis and critical heat flux (AEC critical review series) 1972 by Long Sun (L. S.) Tong.
http://www.amazon.com/dp/B0006C7S84/?tag=pfamazon01-20
There is another version of the curve, I think called "dryout" that I'll see if I can find.
For our on-lookers, the ultimate problem is the hydrogen catastrophe at about 1000°C (as I recall) when our cladding burns in the oxygen released.
That's right. The fourth root. Now I remember. Thank you, Doug.
Related to Results of steam bubbles in the reactor
What are steam bubbles and why are they important in a reactor?
Steam bubbles are pockets of steam that form in a reactor due to the heating of water. They are important because they help to transfer heat within the reactor, which is essential for the production of energy.
Do steam bubbles have any negative effects on a reactor?
While steam bubbles are necessary for heat transfer, they can also cause issues if they become too large or numerous. They can block the flow of water in the reactor, leading to decreased efficiency and potential damage to equipment.
How are steam bubbles controlled in a reactor?
Steam bubbles can be controlled by carefully regulating the temperature and pressure within the reactor. Additionally, design features such as baffle plates and circulation pumps can help to prevent the formation of large steam bubbles.
What are some potential consequences of steam bubbles in a reactor?
If steam bubbles are not properly controlled, they can lead to decreased efficiency and potential damage to equipment. In extreme cases, they can cause a reactor to overheat or malfunction, which could have serious safety implications.
Are there any ongoing research or developments in regards to steam bubbles in reactors?
Yes, there is ongoing research and development in this area. Scientists are constantly looking for ways to improve the control and efficiency of steam bubbles in reactors, as well as ways to mitigate any potential negative effects they may have.
  • Nuclear Engineering
  • Other Physics Topics
