MHB Resurrecting a previous post. Coprime mod n implies coprime-ish mod n.
  • Thread starter Thread starter caffeinemachine
The discussion centers on the mathematical relationship between integers a and b under modular arithmetic, specifically when they are coprime mod n. It explores whether integers a', b', p', and q' can be found such that a'p' + b'q' = 1, given that ap + bq ≡ 1 mod n. The response confirms that if gcd(a, b) = 1, then such integers exist, but raises questions about the scenario when gcd(a, b) ≠ 1. It is noted that if gcd(a, b) divides γ, it leads to a contradiction since it would imply gcd(a, b) = 1, which is not a given condition. The thread seeks further insights on the implications of non-coprime integers in this context.
caffeinemachine
MHB
This was a question posted a long time ago by Swlabr but somehow the thread died.
Let $a$ and $b$ be two integers such that there exists integers $p$, $q$ with $ap+bq=1\text{ mod }n$. Do there exist integers $a^{\prime}$ $b^{\prime}$, $p^{\prime}$ and $q^{\prime}$ such that, $x^{\prime}=x\text{ mod }n$ for $x\in\{a, b, p, q\}$ and, $$a^{\prime}p^{\prime}+b^{\prime}q^{\prime}=1?$$.This was my response.
If $\gcd (a,b)=1$ then yes.
$ap+bq \equiv 1 \mod n$ means there exist integer $\gamma$ such that $ap + bq+n \gamma =1$ . If $\gcd (a, b)=1$ then $\exists k_1, k_2$ such that
$ak_1+bk_2=\gamma$.
Take $a{'} =a, b{'}=b, p{'}=p+nk_1, q{'}=q+nk_2$
Then $a{'}b{'} +b{'}q{'}=1$
I am not sure what happens when $\gcd (a,b) \neq 1$.
Ideas anyone?
The original thread is http://www.mathhelpboards.com/f15/coprime-mod-%24n%24-implies-coprime-ish-mod-%24n%24-624/#post3495
Mathematics news on Phys.org
Re: ressurecting a previous post. Coprime mod $n$ implies coprime-ish mod $n$.
Here's what I think,
From $ap + bq+n \gamma =1$, it's evident that $(a,b)$ is coprime to $\gamma$. Then I look for solutions in the form $p'=p+nx$,$q'=q+ny$, so if we want $ap'+bq'=1$ we are led to $ax+by=\gamma$, which has a solution.
Hey melese! You have helped me a lot at MHF(I used abhishekkgp as my nick there). Thanks for showing interest in this thread.
Now, from what I understand you use the fact that $ax+by=\gamma$ has a solution. Ok.. I'll assume, for the moment, that it does. Write $g=\gcd(a,b)$. This would mean that $g| \gamma$. But from $ap+bq+n\gamma=1$ we'd have $g|1$ as $g$ divides $a,b$ and $\gamma$. This would force that $\gcd(a,b)=1$ which is not a necessity in the hypothesis.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
