- #36
Ibix
- 14,371
Unfortunately, you are attempting to apply "common sense" which is derived from experience with slow moving, small scale systems, to extremely rapid things moving over long distances. The answer "makes little sense" to you because you are attempting to apply an intuitive physical model that is reasonably accurate on some scales to wildly different scales where it is not remotely accurate.Viopia said:I suspect you will you will probably say that the speed of the photons will always be at 299,792 Km per second because they are local to the Earth when they arrive, but I believe this makes little sense.
See the "cosmological sources" section of the experimental basis of relativity FAQ, linked from the sticky thread in the relativity forum:Viopia said:This is a simple experiment to do just to rule this possibility out.
http://www.edu-observatory.org/physics-faq/Relativity/SR/experiments.html#cosmological
