Reverse triangle inequality with a + sign
In summary, the reverse triangle inequality for complex numbers states that $||a|-|b|| \le |a-b|$ for all complex $a$ and $b$. By replacing $b$ with $-b$, we can also conclude that $||a| - |b|| \le |a+b|$. This is why in the given example, the +4 can be replaced with -4 without changing the inequality.
ognik
643
Thought I knew this, but am confused by the following example:
Show $ |z^3 - 5iz + 4| \ge 8 $
The example goes on: $ |z^3 - 5iz + 4| \ge ||z^3 - 5iz| - |4|| $, using the reverse triangle inequality
It's probably right, but I don't get why the +4 can just be made into a -4 ?
The reverse triangle inequality for the complex numbers states $||a|-|b|| \le |a-b|$ for all complex $a$ and $b$. To see this, fix $a, b\in \Bbb C$. Then $|a| = |(a - b) + b| \le |a-b| + |b|$; here, the triangle inequality was applied in the last step. So $|a| - |b| \le |a-b|$. Similarly $|b| - |a| \le |b - a| = |a - b|$. Hence $||a| - |b|| \le |a-b|$.
If we replace $b$ by $-b$ in the reverse triangle inequality above we obtain $||a| -|-b|| \le |a-(-b)|$, i.e., $||a| - |b|| \le |a+b|$. So by letting $a = z^3 - 5iz$ and $b = 4$, we get $||z^3 - 5iz| - |4|| \le |z^3-5iz + 4|$, as desired.
Thanks Euge, perfectly clear now.
FAQ: Reverse triangle inequality with a + sign
What is the reverse triangle inequality with a + sign?
The reverse triangle inequality with a + sign is a mathematical concept that states that for any two real numbers a and b, the absolute value of their sum is always less than or equal to the sum of their absolute values. In other words, it shows that the distance between two points on a number line is always greater than or equal to the distance of each point from the origin.
How is the reverse triangle inequality with a + sign different from the regular triangle inequality?
The regular triangle inequality states that for any two real numbers a and b, the absolute value of their difference is always less than or equal to the sum of their absolute values. The reverse triangle inequality with a + sign, on the other hand, focuses on the sum of the absolute values rather than the difference. It is essentially the opposite of the regular triangle inequality.
What are the applications of the reverse triangle inequality with a + sign?
The reverse triangle inequality with a + sign has various applications in mathematics, particularly in the fields of geometry, analysis, and number theory. It is commonly used to prove the existence of solutions to certain equations and to establish bounds on certain functions and series.
Can the reverse triangle inequality with a + sign be extended to higher dimensions?
Yes, the reverse triangle inequality can be extended to higher dimensions. In three-dimensional space, it states that the distance between two points in space is always greater than or equal to the sum of the distances of each point from the origin. This concept can also be extended to higher dimensions, such as four-dimensional space or n-dimensional space.
How can the reverse triangle inequality with a + sign be proved?
The reverse triangle inequality with a + sign can be proved using various mathematical techniques, such as the triangle inequality, the Cauchy-Schwarz inequality, and the triangle inequality for complex numbers. It can also be proved using geometric arguments, such as the Pythagorean theorem. The specific method used for the proof may vary depending on the context and the level of mathematical knowledge required.
