Reversibility of heat transfer
In summary, reversible heat exchange requires an infinitesimal temperature difference between the system and heat source in each step. This results in a net increase in entropy, but this can be minimized by ensuring a very small temperature difference. However, true reversible processes are not possible in nature and can only be approached in the limit of dT = (T2-T1) → 0.
kelvin490
In the case of reversible heat exchange which the cooler body rises in temperature from T1 to T2, it requires that the temperature difference between the system and the heat source must be infinitesimal in every step. Usually the model is like that: Give a heat reservoir of temperature slightly higher than T1, make a small amount of heat transfer, than the temperature of cold body rise a little bit. Then use another hotter reservoir and transfer another infinitesimal amount of heat, repeat the steps until the body is T2.
The problem is: In every step the entropy decrease of hotter reservoir is smaller than the entropy increase of the cooler body. There is a net increase in entropy of the system. Although the increase is close to zero, we have done infinite number of step in order to increase the temperature to T2. How can we ensure the overall increase in entropy is zero so that it is a reversible process?
Science news on Phys.org
It is reversible only in the limit of dT = (T2-T1) → 0 .
There is no truly reversible process in nature, since such a process would take an infinite time.
Actual processes can at most be very close to reversible.
It is nevertheless a useful concept and it can even be useful as an approximation to actual processes.
Likes 1 person
Related to Reversibility of heat transfer
1. What is the definition of reversibility of heat transfer?
The reversibility of heat transfer refers to the ability of a physical process to be reversed without any net energy loss or change in the system. In other words, the system can be returned to its original state after a heat transfer process has occurred.
2. How does the reversibility of heat transfer relate to the Second Law of Thermodynamics?
The Second Law of Thermodynamics states that in any natural process, the total entropy of the universe will always increase. This means that heat transfer processes are inherently irreversible, as some energy will always be lost in the form of heat. However, in idealized systems and under certain conditions, heat transfer can be reversible.
3. What factors affect the reversibility of heat transfer?
The factors that affect the reversibility of heat transfer include the nature of the materials involved, the temperature difference between the two systems, and the rate at which the transfer occurs. In general, slower and more gradual heat transfer processes tend to be more reversible.
4. Can all heat transfer processes be reversed?
No, not all heat transfer processes can be fully reversed. This is because some energy will always be lost in the form of heat, and it is impossible to perfectly recreate the initial conditions of a system. However, in certain idealized systems and under carefully controlled conditions, heat transfer can be nearly reversible.
5. How is the reversibility of heat transfer important in practical applications?
The reversibility of heat transfer is important in many practical applications, such as in the design of heat engines and refrigeration systems. In these systems, the goal is to minimize energy losses and increase efficiency, so understanding the reversibility of heat transfer is crucial. Additionally, reversible heat transfer processes are often used in experimental settings to measure and analyze thermodynamic properties of materials and systems.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
