Reversible, Isothermal Compression from P1 to P2. How much heat?
In summary, the solution to this problem involves using Maxwell's four relations and the differential forms of the four thermodynamic potentials (Central, Enthalpy, Gibbs, Helmholtz). By setting S=S(T,P) and using the fourth Maxwell relation, it is possible to rewrite the equation as dS = -(dV/dT)P dP and then integrate to find Q = T ∫ dQ between P1 and P2. The validity of setting S=S(T,P) may be called into question, as it goes against the previous use of U=U(S,V) to determine functions of state.
FatPhysicsBoy
62
Compress a body reversibly and isothermally from P1 to P2. How much heat goes in or out?
Maxwells four relations, differential forms of the four thermodynamic potentials (Central, Enthalpy, Gibbs, Helmholtz)
My problem is that I've been told that the way this is done is saying that S=S(T,P) therefore dS=(dS/dT)P dT + (dS/dP)T dP Isothermal hence dS= second term and using the fourth maxwell relation you can rewrite it as:
dS = - (dV/dT)P dP and since it is reversible we have dQ=TdS so dQ = -T(dV/dT)P dP [The derivatives inside the brackets are partial derivatives]
Integrating gives: Q = T ∫ dQ between P1 and P2.
The first part of this solution seems fishy where we say that S=S(T,P) I understand that this is still a function of state, however when deriving the Maxwell relations we used either the central equation and the other differential forms of the thermodynamic potentials to give us an idea of what something was a function of e.g. U=U(S,V) since dU=TdS-PdV
Anyone?
Related to Reversible, Isothermal Compression from P1 to P2. How much heat?
1. What is reversible, isothermal compression?
Reversible, isothermal compression is a thermodynamic process in which the compression of a gas occurs at constant temperature. This means that the energy added to the gas during compression is transferred out as heat, keeping the temperature constant.
2. What is the equation for reversible, isothermal compression?
The equation for reversible, isothermal compression is P1V1 = P2V2, where P1 and V1 are the initial pressure and volume of the gas, and P2 and V2 are the final pressure and volume of the gas.
3. How is reversible, isothermal compression different from other compression processes?
Reversible, isothermal compression is different from other compression processes because it occurs at constant temperature, which requires the transfer of heat in or out of the system. This is in contrast to adiabatic compression, which occurs without the transfer of heat.
4. How is the amount of heat involved in reversible, isothermal compression calculated?
The amount of heat involved in reversible, isothermal compression can be calculated using the equation Q = nRT ln(P2/P1), where Q is the heat transferred, n is the number of moles of gas, R is the gas constant, and T is the temperature in Kelvin.
5. What factors affect the amount of heat in reversible, isothermal compression?
The amount of heat involved in reversible, isothermal compression is affected by the initial and final pressures of the gas, the number of moles of gas, and the temperature. Additionally, the type of gas and the efficiency of the compression process can also impact the amount of heat transferred.
25K
