Rewriting Friedmann Eq. with Conformal Time & Density Params
In summary, the problem statement asks for a relation between conformal time and density parameters. The problem is trying to find a constraint between the density parameters that does not involve normalization of scale factor. The solution is to redefine the density parameter and solve the Friedmann equation using that new parameter.
Tomishiyo
Rewrite Friedmann equation using conformal time and density parameters [itex]\Omega_m[/itex] and [itex]\Omega_r[/itex]. Is there a relation between the two? How many parameters define the problem?
Friedmann equation
[tex]\left(\frac{\dot{a}}{a}\right)^2=\frac{8\pi G}{3c^2}\left(\frac{\epsilon_{0m}}{a^3}+\frac{ε_{0r}}{a^4}\right)[/tex]
Conformal time definition
[tex]dt=a(\eta) d\eta[/tex]
Density parameter:
[tex]\Omega\equiv \frac{ε(t_0)}{ε_c(t_0)}=\frac{3c^2}{8\pi G}H_0^2[/tex]
First part is rather simple: just a matter of changing the variable in Friedmann Equation, noting that:
[tex]\frac{d}{dt}=\frac{d\eta}{dt}\frac{d}{d\eta}=\frac{1}{a}\frac{d}{d\eta}[/tex]
so Friedmann Equations turn out to be:
[tex]\left(\frac{da}{d\eta}\right)^2=\frac{8\pi G}{3c^2}(aε_{m0}+ε_{r0})[/tex]
or in terms of the density parameter:
[tex]\left(\frac{da}{d\eta}\right)^2=H_0^2(a\Omega_m+Ω_r).[/tex]
My trouble starts now. So, normally the densities parameters are constrained due to scale factor normalization, that is to say, they must obey the constrain equation [itex]1=\Omega_m+\Omega_r[/itex]. That relation should hold regardless of the coordinate system I choose to write Friedmann equation, but I cannot see the connection, unless I postulate that there must exist a [itex]\eta_0[/itex] such that [itex]a(\eta_0)=1[/itex], and later find its relation to physical time (and I can only find that once I know [itex]a(\eta)[/itex], i.e, when I solve Friedmann equation). But that does not seem to me as a correct assumption, for the next exercise on my list ask me to make precisely this assumption, indicating that there must exist another way of constraining the parameters. I think, thus, that there must exist a constrain between the density parameters that does not involve normalization of scale factor, but I can't think about anything to solve that. Can anyone help me out?
Thank you!
You're already assuming that [itex]a_0=1[/itex] when you write the Friedmann equation this way. The equation is really
[tex]\left(\frac{\dot{a}}{a}\right)^2=\frac{8\pi G}{3c^2}\epsilon,[/tex]
where [itex]\epsilon[/itex] is the energy density (usually people use [itex]\rho[/itex], but I will keep your notation). For a specific equation of state [itex]p=w \epsilon[/itex], we'll find
[tex] \frac{\epsilon}{\epsilon_0} = \left( \frac{a}{a_0} \right)^{-3(1+w)}.[/tex]
Obviously the factors of [itex]a_0[/itex] have been set to one in your version of the formula.
You can solve the problem by defining a density parameter [itex]\Omega(t) = \epsilon(t)/\epsilon_c(t)[/itex] instead of the way that you've defined it (only at [itex]t=t_0[/itex]). Rewrite the Friedmann equation in terms of these and you'll get what you were expecting without extra scale factors.
First, thank you by your time!
Well, I used the equation that the problem statement have gave me. I agree with you that this assumption is implicit in the equation, but then can I take for granted that the densities will add up to one due to this assumption?
The density parameters will add up to one because the Friedmann equation you've written is for a flat universe. This is really the definition of "critical" in the critical density. It is the value of the total density such that the universe is flat.
Ok, thank you very much. I think I've done it :)
FAQ: Rewriting Friedmann Eq. with Conformal Time & Density Params
What is the Friedmann Equation?
The Friedmann Equation is a fundamental equation in cosmology that describes the evolution of the universe over time. It is derived from Einstein's theory of general relativity and is used to calculate the expansion rate of the universe.
What is Conformal Time?
Conformal time is a time coordinate used in cosmology that takes into account the expansion of the universe. It is defined as the time that light would take to travel a given distance in a flat, non-expanding universe.
How is the Friedmann Equation rewritten with Conformal Time?
The Friedmann Equation can be rewritten using conformal time by substituting the regular time variable with the conformal time variable and incorporating the scale factor of the universe. This allows for a more accurate description of the evolution of the universe.
What are Density Parameters?
Density parameters are dimensionless quantities that describe the amount of different types of matter and energy in the universe. They are used in the Friedmann Equation to account for the effects of matter, radiation, and dark energy on the expansion of the universe.
How do Density Parameters affect the Friedmann Equation?
The density parameters affect the Friedmann Equation by determining the overall curvature of the universe and the rate of expansion. They also play a crucial role in determining the fate of the universe, whether it will expand forever or eventually collapse.
