I Reynolds Number and Turbulence: Why Does Increasing Density Affect Flow?
Increasing fluid density raises the Reynolds number, which indicates a shift from laminar to turbulent flow due to higher inertial forces. The relationship between viscosity and flow velocity is crucial; higher density leads to greater momentum, which creates steeper velocity gradients. These gradients can trigger instabilities in the flow, resulting in turbulence when small perturbations amplify. Essentially, higher density contributes to increased velocity gradients, leading to chaotic flow patterns. Understanding this relationship is key to grasping the dynamics of fluid behavior in various contexts.
chir89
hi. I have a question regarding rheology. the Reynolds number increases when density of a fluid increases. so the flow becomes more turbulent. but I wonder why it is that the flow becomes more turbulent when density increases. why is that?
You should see the Reynolds number as a ratio between the inertial forces and the viscous forces. Higher density of course means higher inertial forces.
So think of a flat plate along which a boundary layer develops (laminar, for now). The outer flow has a certain velocity and the velocity at the wall is zero by definition (the well known no-slip condition, as observed through many experiments). It is the viscosity that inhibits the flow from attaining the free-stream velocity instantly (even with the no-slip condition I mean, this would then cause an infinite gradient, which is of course not physical), so the higher the viscosity the lower the gradient in the flow (and thus the thicker the boundary layer, but I want to keep it to local gradients in the flow).
But, you can flip the argumentation. For equal viscosity, the more momentum is behind the flow, the less viscosity is able to slow down the flow towards the wall, in other words, the higher the momentum, the higher the gradients in the flow.
So, both lower viscosity and higher momentum (either through more fluid, L, higher velocity, V, or higher density, ##\rho##) cause higher gradients in the flow. Turbulence starts when gradients in the flow become too high and thus instabilities arise. This means that small perturbations in the flow do not damp out and grow towards full fledged chaotic flow (eddies and all that).
So, the short answer: higher density causes higher velocity gradients in the flow, causing flow instabilities, causing turbulence.
Likes Lnewqban and pinball1970
Thanks so much! Got it :)
Likes Arjan82 and Lnewqban
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
