Reynolds numbers and inertial force
In summary: A Nusselt number correlation is only valid within a certain range of Reynolds and Prandtl numbers, and even then, extrapolation beyond that range is dangerous at best. So in terms of "predicting" Nusselt number (and thus temperature distribution and heat transfer rate), the Reynolds number is far from a perfect predictor.In summary, the Reynolds number is a dimensionless parameter that represents the ratio of inertial forces to viscous forces acting on a fluid. It is used to determine the transition from laminar to turbulent flow, as well as the magnitude of turbulent velocity fluctuations. It is also used to predict forces and heat fluxes at interfaces in fluid mechanics and heat transfer applications. However
forks11
Reynolds numbers and "inertial force"
I am an undergrad physics major taking an engineering course that just introduced the concept of reynolds numbers. When I try to get an idea of how the Reynolds number is physically derived, I keep running into the definition that it is the "ratio of inertial forces to viscous forces acting on a fluid." Where the "inertial force" is defined as F=mass*acceleration.
As I understand Newtons 2nd law, it means that for an object with mass M to accelerate with acceleration A, the object must be acted on by a net force ∑F=M*A. But F = M*A is not an actual force, but rather a description that says that "acceleration is directly proportional to force and inversely proportional to mass."
The only other time I have seen this concept of "inertial force" is with respect to non-inertial reference frames where objects experience a pseudo-force due to the acceleration of the frame, but that doesn't seem to apply here.
Can anybody explain to me what is meant by "inertial force," or otherwise give me a intuitive or straightforward description of what the Reynolds number describes??
"The inertial forces, which characterize how much a particular fluid resists any change in motion are not to be confused with inertial forces defined in the classical way" - Wiki
A high Reynolds number indicates high turbulence, chaotic flow, while a low number indicates laminar flow, smooth flow. Wiki gives a good explanation of the specific ratio that is the Reynolds number (of the scales of turbulence wrt energy dissipation).
The "inertial forces" in this case do effectively refer to the fluid's mass and therefore tendency to resist movement by an external force. The term in the numerator is essentially a mass flux term multiplied by a length scale.
The Reynolds number basically represents the importance of viscosity to the flow field relative to effects of the overall fluid motion. For very high Reynolds numbers, the flow can often be approximated reasonably accurately as inviscid, for example.
This is incredibly false. There is no universal correlation between Reynolds number and the onset of turbulence. In general, as the Reynolds number gets higher, the flow is more likely to transition, but it is not a measure of turbulence or an absolute indicator of turbulence.
The Reynolds number can be manipulated mathematically as follows:
Re = ρvL/μ = (ρv2)/(μv/L)
where L is the characteristic length scale for the system. The quantity μv/L is like the viscous shear stress, and is loosely referred to as the "viscous force." The quantity ρv2 is like the kinetic energy per unit volume, and is loosely referred to as the "inertial force." Saying that the Re is the ratio of inertial forces to viscous forces is no more precise than this, so don't take it too seriously. It is more of an intuitive notion.
The Reynold's number is a way of quantifying how much force is needed to change the direction of the fluid flow whether comp. or incomp. so it's not a measure of turbulence, it's a dimensionless value to depict exactly what you said in your question..."ratio of inertial forces to viscous forces acting on a fluid". It is used to essentially unify an understanding of the effects of viscosity and the momentum of each particle. The penny will drop so to speak when you perform any wind tunnel tests and you'll see why it's relevant.
The Jericho.
The Jericho.
Based on decades of experience if fluid mechanics, I can tell you that I have never heard anyone describe the Reynolds number in this way. The force needed to change the direction of a fluid flow is primarily related to a change in momentum (inertial), and has very little to do with viscous effects. In addition, for a given flow (e.g., flow in a pipe), the Reynolds number is used in practice to determine the transition from laminar flow to turbulent flow (for pipe flow, the transition is 2100), and also correlates quantitatively with the rms magnitude of the turbulent velocity fluctuations. In fluid mechanics, the fluid is treated as a continuum, and there are no individual particles involved. Certainly, viscosity is a continuum concept.
How is the Reynolds number used in practice? In both fluid mechanics and heat transfer, it is used to determine the forces and heat fluxes at interfaces. In turbulent pipe flow, for example, the shear stress at the wall can be predicted if the Reynolds number is known. Knowledge of the shear stress at the wall is necessary to predict the pressure drop. In turbulent heat transfer, the heat transfer coefficient at the wall is a function of two dimensionless groups, the Reynolds number and the Prantdl number. Knowledge of the heat transfer coefficient at the wall is necessary to predict the temperature change of a fluid passing through a heated pipe.
In the end it doesn't REALLY predict heat transfer or shear stress either in the normal sense of "predict." It is a similarity variable that therefore correlates well with quite a few parameters on interest in fluid mechanics.
Take for example heat transfer. Yes the Nusselt number depends on Reynolds number and Prandtl number, but that relationship changes for different ranges of both and for laminer or turbulent flow. The Reynolds number itself doesn't have any real predictive capability, therefore. It just works nicely with many correlations and models due to its nature as a similarity variable.
Yes. I totally agree. The wording I employed was that it is used to predict the drag and the heat transfer. I didn't mean to imply that, without the experimental correlations, it can have predictive power on its own. But, of course, for laminar flow, the experimental correlations aren't really necessary, since the behavior can be predicted analytically.
Fair point. That's why it's fun to be someone who works on almost exclusively laminar flows.
Related to Reynolds numbers and inertial force
1. What is a Reynolds number?
A Reynolds number is a dimensionless quantity used in fluid mechanics to characterize the ratio of inertial forces to viscous forces within a fluid flow. It is named after Osborne Reynolds, a British physicist who pioneered research in fluid dynamics.
2. How is a Reynolds number calculated?
A Reynolds number is calculated by taking the product of the fluid's density, its velocity, and a characteristic length scale of the flow, and dividing it by the fluid's dynamic viscosity. The resulting value is unitless and represents the ratio of inertial forces to viscous forces.
3. What is the significance of a high Reynolds number?
A high Reynolds number indicates that the fluid flow is dominated by inertial forces, meaning that the flow is turbulent and chaotic. This can result in increased mixing and faster heat and mass transfer, making it important in many industrial and natural processes.
4. How does the Reynolds number affect the behavior of a fluid flow?
The Reynolds number determines the type of flow regime that a fluid will exhibit. At low Reynolds numbers, the flow is laminar and smooth, while at high Reynolds numbers, the flow is turbulent and chaotic. In between these two extremes, the flow can exhibit a transitional behavior.
5. What is the practical application of Reynolds numbers?
Reynolds numbers are used in many engineering applications, such as in the design of pipes, pumps, and airfoils. They are also important in understanding natural phenomena, such as the formation of waves and currents in bodies of water. Additionally, Reynolds numbers are used in the study of biological systems, such as the flow of blood through arteries and veins.
  • Classical Physics
  • Mechanics
  • Mechanical Engineering
14K
