RG flow of quadrupole coupling in 6+1 dimension electrostatic problem
The discussion focuses on applying the Euler-Lagrange equation to a specific Lagrangian related to a 6+1 dimensional electrostatic problem. The initial attempt to solve the equation using perturbation theory revealed that the relevant terms in the action do not depend on the parameter Q, leading to confusion. The response clarifies that the only term containing the coupling constant λ is the second one, which leads to the derived equations being independent of Q. The final Euler-Lagrange equations obtained are ∇²σ = 0 and ∇²φ - λσ(∇φ)² = 0. This indicates that the coupling does not influence the dependence on Q in this context.
DaniV
Given a classical action which describes electrostatics in 6+1 dimensions
$$\frac{S_\text{eff}}{T}=\frac{1}{2} \int d^6x(\nabla\phi)^2+\frac{S_{p.p}}{T}$$
where the one particle action, that represents the energy of the monopole dipole and quadrupole induced by charge distribution around the origin is:
$$\frac{S_{p.p}}{T}=-q\phi(0)-D\nabla_i\phi(0)\nabla^i\phi(0)-Q\nabla_i\nabla_j\phi(0)\nabla^i\nabla^j\phi(0)+...$$
Now we add to the theory a scalar field ##\sigma## that couples to the potential ##\phi## so the action becomes:
$$\frac{S_\text{eff}}{T}=\int d^6x\left[(\nabla \phi)^2+(\nabla \sigma)^2+\lambda\sigma (\nabla \phi)^2\right]+\frac{S_{p.p}}{T}$$
and the system is subjected to an external quadrupole background $$\bar \phi=\frac{1}{2}\rho_{ij}x^ix^j$$ when ##Tr\rho_{ij}=0##
i.e. ##\phi \to \phi+ \bar \phi## where ##\phi## describes the classical response of the charge distribution at the origin to the external perturbation ##\bar \phi##, and we assume that ##\frac{q^2\lambda^2}{Q^2}\ll1##
I want to calculate the RG flow of the coupling ##Q##,
using Minimal subtraction renormalization scheme and dimensional regularization.
Euler Lagrange for fields:
$$\frac{\partial \mathcal L}{\partial \phi}=\partial_{\mu}(\frac{\partial \mathcal L}{\partial (\partial _{\mu}\phi)})$$
dimensional regularization:
we put $$2\epsilon=d-4$$ when d is the dimension , solving divergent integrals by expanding to small ##\epsilon## and then as we approach to final result we take ##\epsilon \to 0##
Minimal subtraction renormalization scheme:
defining new couplings using the old ones in way that they cancel divergent part of the solution.
RG flow:
the flow of the coupling constant in the dependence of energy scale ##\mu## given by the beta function ##\beta(Q)=\mu \frac{\partial Q}{\partial \mu}##
I tried to do a Euler Lagrange equation to our Lagrangian:
and then I would like to solve the equation using perturbation theory when ##Q## or somehow $$\frac{q^2\lambda^2}{Q^2}\ll1$$ but when itried to do the equation I got that is not depend on Q at all because the relevant term in $$S_{p.p}$$ is just derivatives of the field $\phi$ in the point zero (so its acting like constant) or am I wrong?
A:To do the Euler-Lagrange equation, you need to take derivative of the action with respect to the respective fields. The only term containing $\lambda$ is the second one, so we will concentrate there. $$\delta S = \int d^6x \left[2\lambda \sigma \nabla \cdot \phi \delta \nabla \phi + \lambda \sigma (\nabla \phi)^2 \delta \sigma \right]$$We can use integration by parts on the first term and use the fact that the field is periodic to obtain$$\delta S = \int d^6x \left[-2\lambda \phi \nabla \cdot \sigma \delta \nabla \phi + \lambda \sigma (\nabla \phi)^2 \delta \sigma \right]$$Integrating the first term by parts again, and using periodicity of the field again, we obtain$$\delta S = \int d^6x \left[2\lambda \phi \nabla^2 \sigma \delta \phi + \lambda \sigma (\nabla \phi)^2 \delta \sigma \right]$$The Euler-Lagrange equation then is$$\nabla^2 \sigma = 0$$$$\nabla^2 \phi - \lambda \sigma (\nabla \phi)^2 = 0$$These equations are independent of $Q$.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
